Powered relief system -- I can hear you laughing from here....
Old May 2nd 06, 08:16 PM posted to rec.aviation.soaring
Default Powered relief system -- I can hear you laughing from here....
OK, here goes: After reading all those recent posts about removing
self-adhesive external male catheters, I'm going to put my already
dubious reputation at risk and share my "invention." I have a
Powered-Pee-Pump in my glider. Now don't laugh so hard - everyone
does, till they get a closer look at the thing and a little lightbulb
goes off over their heads....
Here's the deal: as a new pilot I found that the usual methods for
relief were pretty damn distracting and I'd look up from the baggie
and see my ASI approaching redline. (Found I was putting the nose down
to encourage gravity flow....) And I simply wasn't interested in
wearing a condom the whole time I was flying, (it's supposed to be
"free-flight" after all,) or the hassle of un-gluing, etc. Then I
realized my glider has an electrical system.
So, I found a small, corrosion resistant, self-priming 12-24 VDC liquid
pump from these guys: http://www.smartproducts.com/liquid.html
They had an "R&D" special price of $25 for the first one. It has
mounting tabs allowing it to be easily screwed to any flat surface;
mine went onto the floor of my 1-35 just ahead of my instrument panel.
The pump is fitted with 1/8" NPT barbs so it was very easy to plumb
tubing onto. I used a length of flexible latex tubing on the "from"
side, and cheap pvc tubing on the exit side. Pump is wired to fuse and
toggle switch in my panel.
For the "connector" I used a small rubber bulb from an
old-fashioned child's bicycle horn. I super-glued the latex hose into
the small end of the bulb. I cut and radiused a hole in the large end
of the bulb, "custom-sized" for a snug but comfortable fit.
(You're on your own here....) I drilled a 1/16" vent hole in the
side of the bulb which is normally facing upwards, when the bulb is
deployed. OK, now here's the fun part. To don the "connector", I
simply switch on the pump, which creates a small vacuum. Then I cover
the 1/16" whole with my thumb and hold the large hole against the
head of the little guy for a few seconds, and it
"self-installs".... I release the small vent hole, concentrate on
flying, and there's no muss, no fuss. When done, I disconnect with
pump still running, tip the bulb vertically to completely drain, stow
the bulb, and flip the switch off. At the moment, I am using a
two-liter plastic soda bottle (mounted in what was a capacity flask
mount in the nose of the glider) for waste storage. Bottle has a tiny
vent hole at very top and does not leak. I will eventually plumb a line
out the tail or wheel well. For the time being, the standing joke is
about moving the CG forward during the flight by slowly transporting
liquid from the Camelbak mounted behind the seat into the reservoir in
the glider's nose.
Gravity and spillage are a non-issue. The damn thing has worked
flawlessly every time since I installed it about two years ago. Current
draw seems minimal. (I still carry a baggie as back-up is always a good
idea....) Total, one-time cost about $35. No, there is no "vibrate"
option, and, no, I'm not going to take pictures of it in use!
There, my dirty little secret is out of the bag. (What did I just let
myself in for?!)
Blue skies, Paul
Old May 2nd 06, 08:27 PM posted to rec.aviation.soaring
Johnny come lately! I had the same setup in my nimbus 3. My pump
was fitted after the holding tank so pee into the holding tank and
motor vents the waste to atmosphere. The advantage of this setup is
that if you really have a big 'ballast' load the initial surge does not
overcome the pump and cause an embarasing situation.
Oh, I once removed the seat pan to service something and connected the
pump ....... backwards ....... it didnt backflush but it didnt dump
either!
Old May 2nd 06, 10:20 PM posted to rec.aviation.soaring
I get basically the same effect without a motorized pump. My dump tube
extends down from the fuselage about a foot, and curves aft due to
airpressure. Result is suction at the collection "bulb" that
effectively scavenges all fluid from the bulb - even when used "uphill"
(which is pretty much required in an LS6!).
After use, I clean (flush?) the system by pouring some water into it,
then retract and stow the relief system. Never found any stains on the
glider - although I usually use a little cross-control just in case
while evacuating.
The relief system consist of a length of stiff tube (some kind of
translucent plastic), a short length of rubber surgical tubing (flex
coupling), and a collection bulb fashioned out of an ear cleaning bulb,
trimmed to fit. It's a slip fit into a tube mounted vertically just
behind the stick, with flush exit hole on bottom of fuselage when not
in use, capped off in cockpit to avoid air leakage.
To be fair, it came with the ship - setup for a catheter - which I may
try someday.
Kirk
66
Old May 3rd 06, 02:12 AM posted to rec.aviation.soaring
For the absolute final word on this subject buy the Platypus (Mike
Bird) book; even my wife thought it was funny and there's not much
about soaring that amuses her.
Ray Warshaw
1LK
Question about the F-22 and it's radar. Scott Ferrin Military Aviation 128 June 13th 04 01:23 AM
"System Failure Is Blamed In U.S. Downing Of British Jet" Mike Military Aviation 20 May 21st 04 06:39 PM
Mother Russia closer to develop an ABM system Alejandro Magno Military Aviation 11 January 11th 04 06:06 PM
