Multi engine plane for PPL or Pilot Training
Old May 3rd 06, 01:22 PM posted to rec.aviation.piloting
Default Multi engine plane for PPL or Pilot Training
I just want to ask question which is quite interesting, or i might do if it
is possible:
Can i use a multi enginer plane (like Piper) for my training for the whole
250hrs required for CPL?
Which means i get my PPL & instrument rating in the multi engine plane.
Old May 3rd 06, 05:53 PM posted to rec.aviation.piloting
If you can afford it, go for it. The late Danny Kaye (you may be too young
to remember him) got his private in a twin. The big problem is going to be
insurance, because the insurance company almost certainly will not provide
coverage for solo flight, and solo is required for the ticket. Kaye, being a
movie star, probably self-insured.
Bob Gardner
"Louis Tse" wrote in message
is possible:
Old May 3rd 06, 06:56 PM posted to rec.aviation.piloting
is possible: Can i use a multi enginer plane (like Piper) for my
training for the whole 250hrs required for CPL?
Do you really want to solo in a multi? That seems to be exceptionally
dangerous AND expensive.
You have to practice power-on and power-off stalls, short- and soft-field
landings and all of that and not only that, you have to worry about landing
gear and twice the engine-performance issues...
Possible? Maybe. But doing what -may- be possible goes against the very
fundamentals of responsible aviation.
-c
Old May 4th 06, 01:39 AM posted to rec.aviation.piloting
I don't think there's any reg that says you can't, but why would you
want to? The PPL is tough enough in a fixed-gear single, why make it
more complicated by adding gear, props, and a second engine with all
the engine-out performance issues that go with it? The money you would
spend just on the PPL would be scary. I had one of my students ask me
about it years ago and we figured out how much it would cost just based
on the national average of 65-70 hours. It was almost double IIRC.
Chances are it'd take significantly longer to get the PPL in a twin so
that 65-70 figure is conservative. The cheapest twin around here to
rent - there's only one that I know of - is a Seneca I that goes for
$230/hr and with the MEI added is $275. Ouch. I do know of a guy that
did all his PPL training in a Bonanza (he had more money than God) and
it took him almost 100hrs to get it done.
Old May 4th 06, 01:43 AM posted to rec.aviation.piloting
Also, when you are done, you won't have single engine land privileges,
just mutiengine. So you won't be able to be PIC in a single without
another checkride.
Old May 4th 06, 02:53 AM posted to rec.aviation.piloting
It's not dangerous... if that is how you are trained.. that is all you know.
Lets just think about all those military pilots that the first aircraft they
ever flew was a twin JET, T-37.
Granted not many do full power on stalls in a twin prop.
BT
Old May 4th 06, 02:54 AM posted to rec.aviation.piloting
Same thing happens if he goes the SE route.. he can't be PIC in a twin
without another check ride.
So what's your point?
BT
"Doug" wrote in message
another checkride.
Old May 4th 06, 04:42 AM posted to rec.aviation.piloting
I have regularly done full stalls in the full line of Beech
twins, from the B95-55 and B55-58, 58P &TC to the King Air
90,20 and 300 series. They stall just fine, recover just
fine and are controllable while in the stall. The Duchess
was even run through the full FAA stall -spin certification,
including single -engine stalls and spin and it recovers
just fine. It was decided not to actually certify the
airplane, but a competent pilot should have no trouble with
any straight wing twin doing balanced power stalls. Some
might be a problem if they are unstable or out of the proper
CG range.
James H. Macklin
ATP,CFI,A&P
some support
"BTIZ" wrote in message
news:i8d6g.18022$Qz.1207@fed1read11...
be exceptionally
first aircraft they
| BT
Old May 4th 06, 04:49 AM posted to rec.aviation.piloting
While working on my CFI, I was invited to observe an instructor
teaching a primary student in a Cessna 336..a fixed gear center-line
thrust twin. This choice of aircraft simplified things a bit since
hedidn't have to worry about the complexity of retractable gear or
asymmetric thrust. He was, however, limited centerline thrust twin
only.
Seems like doing engine out work during the checkride should earn him a
SEL as well.
Old May 4th 06, 05:09 AM posted to rec.aviation.piloting
SEL as well.
.... limited to asymmetric thrust singles.
Jose
The price of freedom is... well... freedom.
Student Drop-Out Rates...why? Jay Honeck Piloting 254 September 1st 05 12:00 AM
Sport Pilot pilots not insurable? Blueskies Piloting 14 July 12th 05 05:45 AM
