Subaru phase II engine weights
Old May 9th 06, 07:12 PM posted to rec.aviation.homebuilt,rec.autos.tech,alt.autos.subaru
Default Subaru phase II engine weights
I can find quite a quite a lot of information on the internet about the
weights of older Subaru engines - although it's not always clear what's
included - but nothing on current/newer engines. Does anyone have good
figures for "phase engines" or comparisons between different types,
e.g. sohc v. dohc, 2.5 v. 2.0, normally aspirated v. turbo? I'm more
interested in low weight than in maximum power/torque.
Tony
Old May 12th 06, 10:08 PM posted to rec.aviation.homebuilt,rec.autos.tech,alt.autos.subaru
Hi Tony,
Turbo motor is heavier than the N.A. versions as the plumbing weights alot
more. 2.5L is essentially same as 2.0 L just bigger bores. I'd stroke a
2.5L to a 2.8 L to maximise a N.A. engine. Phase II 2.5L was SOHC instead
of DOHC and stronger block. (more material around cylinders so you don't
blow head gaskets all the time).
Greg
Tony
Old May 15th 06, 06:04 PM posted to rec.aviation.homebuilt,rec.autos.tech,alt.autos.subaru
Tony,
Mykal Tempelton runs Stratus Subaru and may have that info for you.
Check out the Stratus Subaru web site:
http://www.stratus2000.homestead.com...snew/index.htm
Rex
Avid Flyer with Stratus Subaru EA81
Centurion FAQ with kibbitzing Bret Ludwig Home Built 0 November 12th 05 11:39 PM
Towing Roger Fowler Soaring 6 August 11th 05 05:25 AM
ROP masking of engine problems Roger Long Owning 4 September 27th 04 08:36 PM
Corky's engine choice Corky Scott Home Built 39 August 8th 03 05:29 AM
Engine weights Salem Farm & Garden Home Built 5 July 22nd 03 05:27 AM
