Finally: The right-sized Thielert
Old May 17th 06, 09:07 AM posted to rec.aviation.owning
Default Finally: The right-sized Thielert
Thielert has announced a diesel engine in the 230-HP-range, covering
the gap between the existing 135- and 350-HP models. Great news, IMHO,
since this is the kind of power many of the planes we fly need. First
target for certification seems to be the 182. Time frame is 2007. Nice!
Thomas Borchert (EDDH)
Old May 17th 06, 05:09 PM posted to rec.aviation.owning
It would be interested to see what their cost would
be for an engine that was certified to replace the 250HP
Lycoming IO-540C4B5 engines on my Aztec. I'd
guess that even at engine overhaul time, econmics
would be vastly in favor of overhauling the old engines
as compared to replacing them with diesels.
Ronnie
"Thomas Borchert" wrote in message
Old May 17th 06, 05:45 PM posted to rec.aviation.owning
Ronnie
My thought is it is going to depend on a lot of factors.
Will the cost of swapping a gas engine for a diesel come down as
they become (if it happens) more common?
How will the life-cycle costs compare? Supposedly the diesels require
less maintenance over their life. Whether that is really true or
not remains to be seen. Right now about the only thing for sure is you
don't have to replace spark plugs.
What is going to happen to fuel costs? Right now Jet A is $.87/gal
cheaper at my local FBO. Will this spread increase or decrease?
Will a FADEC diesel further reduce the fuel costs by keeping everything
optimal?
No matter what happens with the above, putting a different engine
in will cost more than putting in a new engine of the same type.
How long do you expect to keep the airplane and how many engines
do you expect to replace/overhaul during that time?
etc.
Jim Pennino
Remove .spam.sux to reply.
Old May 17th 06, 06:32 PM posted to rec.aviation.owning
The biggest cost item is what will the insurance companies consider to
be the likely product liability costs of this new powerplant? Remember
the liability tail is still 18 years, and even this is reset if parts
are replaced. Insurance companies are pretty conservative on
innovation, and for good reasons.
My read on it is that over a long term, the US light aircraft industry
is destined to go overseas where the liability costs of innovation are
less. We'll still have new aircraft (occasionally) but without
additional tort reform in the US, the imported costs will continue to
rise.
Old May 17th 06, 08:37 PM posted to rec.aviation.owning
Diesel actually has a substantial advande in fuel economy. The Tielert
diesel claims to have a BSFC of 0.33lb/HP-hr, far better than the
gasoline engines that're usually at 0.40-0.45 range. If you think this
is not significant, consider that diesel weighs more per gallon than
avgas, and we buy fuel in volume, not weight. So a 25% improvement of
BSFC by going diesel will actually result in 28% of saving in the
volume (gallon) of fuel burn. If the cost of diesel per gallons is 20%
lower than avgas, the total fuel cost saving is going to be about 34%
in dollar amount. That's very significant over the life time of an
engine.
optimal?
Old May 17th 06, 09:18 PM posted to rec.aviation.owning
I thought the fuel for these aviation diesel engine
was Jet A. Is the data below for Jet A or for
diesel fuel?
How does Jet A compare to gasoline?
Ronnie
"M" wrote in message
ps.com...
engine.
optimal?
Old May 17th 06, 09:28 PM posted to rec.aviation.owning
I was using the term diesel fuel in a generic sense. Yes the math is
based on Jet A because it's 6.84lb/gal compared with 6lb/gal of avgas.
diesel fuel?
Old May 29th 06, 04:06 AM posted to rec.aviation.owning
"Ronnie" writes:
diesel fuel?
Jet A == kerosene.
Gasoline is 6.25 lbs/gallon {at ~70F}
Kero is 6.84 lbs/gallon...
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
Old May 18th 06, 01:42 AM posted to rec.aviation.owning
Jet A is more expensive out our local pumps than 100LL but about 80cents.
BT
ps.com...
engine.
optimal?
Old May 18th 06, 02:09 AM posted to rec.aviation.owning
On Wed, 17 May 2006 17:42:17 -0700, "BTIZ"
BT
How much is home heating oil?
Don
FlightAware web site -- finally free flight tracking Chip Hermes Instrument Flight Rules 24 September 15th 05 02:34 AM
FlightAware web site -- finally free flight tracking Chip Hermes Piloting 23 September 15th 05 02:34 AM
It's finally running! Corky Scott Home Built 19 April 29th 05 04:53 PM
Finally got my X-country in.. PJ Hunt Rotorcraft 0 December 18th 04 10:50 AM
Finally flying new Skyhawks! Scott Schluer Piloting 11 February 24th 04 10:02 PM
