Toronto airspace transition
Old May 18th 06, 07:29 AM posted to rec.aviation.piloting
Default Toronto airspace transition
I will be flying through the Toronto airspace from the southwest,
landing at Buttonville (CYKZ). It would most likely be IFR. I realize I
have to detour around Pearson (CYYZ) to the north or south. I don't
know if there are standard fixes that ATC assigns for aircraft
transitioning the airspace. My preference was to plan a southerly route
along the lake shore because it is more scenic. But the class B shelf
looks pretty low over the lake, and I don't want to end up being
vectored too far over water. I would like to hear from anyone who has
flow this route. Thanks!
Old May 18th 06, 02:31 PM posted to rec.aviation.piloting
In article .com,
Andrew, in the past, when I have flown VFR from Columbus OH (Don
Scott/KOSU) to Toronto Island, the only over water I have flown was from
Hamilton to the Island.
Even then, that was just offshore.
Old May 18th 06, 03:53 PM posted to rec.aviation.piloting
"Andrew Sarangan" writes:
realize I have to detour around Pearson (CYYZ) to the north or
south. [...]
Unless you specifically file a roundabout way such as YKF YMS KZ,
Toronto Terminal will just vector you when you get within 25 nm. If
you want to follow the lakeshore east, they'll be happy to let you.
- FChE
Old May 18th 06, 05:07 PM posted to rec.aviation.piloting
Recently, Andrew Sarangan posted:
I have to detour around Pearson (CYYZ) to the north or south. I don't
route along the lake shore because it is more scenic. But the class B
shelf looks pretty low over the lake, and I don't want to end up being
I've flown into Buttonville VFR by following the lakeshore route.
Depending on the direction of your approach into Toronto, this may be
shorter than going around Pearson to the west. Once you've contacted
Toronto ATC, they will vector you as needed. As was mentioned, you would
probably wind up talking to City Center as you approach their airspace,
but that's not a problem. On one of my trips, I was further over water
than glide distance, should the engine suffer a major failure, but I
didn't see that as an unreasonable risk because there wasn't any better
place on the shore to put down anyway.
Regards,
Neil
Old May 19th 06, 08:11 AM posted to rec.aviation.piloting
"Andrew Sarangan" wrote in
If you're IFR, plan a route north of the city or expect to spend some time
over the water. If you can cancel IFR to the west or southwest, then you'll
be handed off to Toronto Terminal (mostly VFR) and then CYTZ (Toronto City
Centre Tower). There's nothing much happening in City Centre airspace so
you can do pretty much whatever you like. If the East-West runways are in
use at Pearson (CYYZ) then expect to be given 2500' along the shore. The
Class C floor there is 1600' but Terminal usually allows 2500'. If the wind
is strong from the North, forget about getting above 1600'. But, even
then, the view is nice.
moo
Air Force One Had to Intercept Some Inadvertent Flyers / How? Rick Umali Piloting 29 February 15th 06 05:40 AM
terminology questions: turtledeck? cantilever wing? Ric Home Built 2 September 13th 05 10:39 PM
Nearly had my life terminated today Michelle P Piloting 11 September 3rd 05 03:37 AM
NAS and associated computer system Newps Instrument Flight Rules 8 August 12th 04 06:12 AM
USAF = US Amphetamine Fools RT Military Aviation 104 September 25th 03 04:17 PM
