CFI Lesson Plan Format Question
Old May 25th 06, 01:32 AM posted to rec.aviation.soaring
Default CFI Lesson Plan Format Question
I've come to something I can't find definite regulations for. Does a lesson
plan have to be in a certain format? I have a couple of examples of formats
but I don't know which one to use. I have a format I would like to use. This
is all for the CFI-G check ride and I know I wont use them much during
actual instruction. Also are the lessons requires to be broken up into each
individual element or can they be comprised of everything you would do on
that flight? Say instead of the lesson being on boxing the wake, it's on
boxing the wake, turns to headings, etc.?
----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure Usenet News==----
Old May 25th 06, 02:05 AM posted to rec.aviation.soaring
if you are going to take a CFI-G check ride, then it might be best to use
the lesson plan format found in the CFI prep materials that follow a
standard "and accepted" FAA Format.
BT
"Slick" wrote in message
lesson
formats
This
each
News==----
Newsgroups
Old May 25th 06, 02:26 AM posted to rec.aviation.soaring
Lesson plans are formal for a reason; they keep you
on task. If you have a good lesson plan in your head
it is not necessary to write it out, but you will waste
a lot of time if you just jump in and go fly to see
what you can figure out that the student needs. You
should really have a syllabus to keep you on track
and be sure that you cover everything required.
It ain't 1970 no more.
that follow a
standard 'and accepted' FAA Format.
BT
'Slick' wrote in message
for. Does a
lesson
of examples of
formats
This
each
you would do on
the wake, it's on
Usenet
News==----
Newsgroups
via Encryption
UAV's and TFR's along the Mexico boarder John Doe Piloting 145 March 31st 06 07:58 PM
Most reliable homebuilt helicopter? tom pettit Home Built 35 September 29th 05 03:24 PM
Boeing Boondoggle Larry Dighera Military Aviation 77 September 15th 04 03:39 AM
