Still in Shock
Old May 25th 06, 05:26 PM posted to rec.aviation.owning
Default Still in Shock
My Archer is in annual and I ask the A&P to check on replacing the trim
switch on the yoke. It has been getting a little hard to get it to
activate in the "down" direction.
He just called and said Piper wanted about $325 for the SWITCH. I
looked in Aircraft Spruce and a non PMA switch is about $25.
Manual trim isn't that bad but it seems a shame to lose a function
because of "attempted rape".
Chuck
Old May 25th 06, 05:32 PM posted to rec.aviation.owning
I don't know how much actual instrument flying you do, but in my Bonanza,
which is flown quite regularly in the Northeast US IMC, the trim wheel is
just low enough on the panel that it makes flying without a trim switch in
IMC a tad uncomfortable.
Last week my pitch computer of the AP was removed by avionics for some
maintenance. Not only did they INOP the AP, but they also disabled the
electric trim. On a round trip flight to across New England in IMC I
discovered how much I really missed that switch.
Peter
Old May 25th 06, 06:00 PM posted to rec.aviation.owning
Looks like Piper is starting to take pricing hints from Raytheon.
In a simular situation, I know people who have pulled the switch, found
the product number and original manufacturer of it and went pawing
though their favorite electronic parts catalog (Mouser, Allied, etc).
Found an exact match, but the price was only a couple of dollars.
Approved part? Absolutely not. Could anyone ever tell the differance?
Absolutely not. Would *I* ever actually use such a thing? Oh, no, never.
Not me. My 57 year old plane has completely factory authorized parts on
it and I challenge anyone to prove otherwise.
I don't have electic trim. Never have had it. Unlike Peter R. with his
Bonanza, I don't find using the trim wheel difficult in my Bonanza. On
the other hand, I suspect he has a lot newer plane than I do.
Frank Stutzman
Bonanza N494B "Hula Girl"
Hood River, OR
Old May 25th 06, 06:08 PM posted to rec.aviation.owning
1973 V35B. And, as a reminder, I was referring to hand flying in IMC with
the manual trim wheel.
Peter
Old May 25th 06, 06:26 PM posted to rec.aviation.owning
Gee, I'm not sure why are you surprised. I just paid $400 for a $2
piece of rubber for my Mooney.
Old May 25th 06, 08:17 PM posted to rec.aviation.owning
Even $25 is way too much. As an A&P and practicing engineer, I would
never suggest that you simply pull the switch out, find one that looks
and functions the same (good sources include Mouser, Digikey, and
Newark), and install it. After all, that would not be an approved
part, so you would not be able to make the proper logbook entry.
Remember, safety is all about complying with the regulations. And you
can't spell complying without lying.
Michael
Old May 25th 06, 08:25 PM posted to rec.aviation.owning
"Michael" wrote in message
Nor would this A&P IA, engineer, and avionics author ever recommend such an
approach. No siree, not me, not hardly ever. "Switch? What switch. It
must have been put on there before I bought the airplane."
Old May 25th 06, 08:31 PM posted to rec.aviation.owning
1973 V35B.
And mine is a 1949 A35. There are quite a bit of differances in the
Bonanzas over the years.
As was I. I'm one of those scary guys who flys a high performance single
IFR without even (*gasp*) an autopilot. I must confess, though, that I
tend to keep the IFR flights on the relatively mild side.
Frank Stutzman
Hood River, OR
Old May 25th 06, 08:46 PM posted to rec.aviation.owning
We had a Mooney shop that figured out that Mooney gear actuator gears
are actually the same as some Cessna flap gears (the manufactor shipped
some to Cessna and some to Mooney). For about 3 years you couldn't get
Mooney gears so this shop grabbed a bunch of the Cessna ones. A friend
of mine bought some and about a month later got a call from the FAA in
Sacramento. They knew that Mooney gears could not be found and wanted
to know how he got his. The FAA was hoping most Mooneys would just be
grounded. Grounding the GA fleet would improve the aviation safety
record.
-Robert
Old May 25th 06, 09:02 PM posted to rec.aviation.owning
IMC the entire route from Syracuse to Boston Logan airport, on an Angel
Flight with a hesitant mother and child as passengers? Single pilot I
must confess that I prefer an AP.
Peter
Shock Mounting Gyros Doug Palmer Home Built 9 January 4th 06 09:38 PM
Shock Chord Rings smjmitchell Home Built 1 September 9th 04 08:41 AM
Shock *Heating*? Jay Honeck Owning 48 February 25th 04 04:43 PM
IS28B2 Lark shock strut parts Dale Walker Soaring 4 February 18th 04 01:45 AM
Avoiding Shock Cooling in Quick Descent O. Sami Saydjari Owning 32 January 21st 04 05:32 AM
