Self Serve Fuel Warning
Old May 30th 06, 03:17 AM posted to rec.aviation.piloting
Default Self Serve Fuel Warning
Same thing when you go buy gas for your Pinto.
-Robert
Old May 30th 06, 03:28 AM posted to rec.aviation.piloting
$1 vs $150
Old May 30th 06, 05:19 AM posted to rec.aviation.piloting
$1 vs $150
What gas station only puts a $1 hold on your card? Most are between
$30-$50. $150 makes sense at the gas pump because the pump doesn't know
how much you are going to put in. If you don't like it you can tell the
pump an exact amount.
Old May 30th 06, 12:45 PM posted to rec.aviation.piloting
Robert M. Gary wrote:
$1 vs $150
All of them that I use, Sunoco, Citgo, Mobil, and Texaco. I have never
typed an amount into a pump, and if it isn't pay at the pump, I don't
stop. I just swipe the card, push "credit" and fill up.
I have a Visa that has GREAT web access. If I use the card, "Temp
Authorizations" are there before I can drive home, literally within
minutes. The "Temporary Charge" will sit there until the real charge
clears, which is normally about three days.
Typical temp charges I see:
Auto Gas: $1
Restaurants: The actual check amount minus tip (corrected amount with
tip clears with actual charge)
Hotels: The amount the establishment runs as a pre-auth - very variable
Everything else (retail): The actual amount
Again, I don't necessarily care. I've never been over billed, and I've
never had a problem. I posted this for folks who prefer debit cards
with credit card logos.
FWIW, My other Visa never shows the temp charges, only a reduction in
available limit with no explanation.
Old May 30th 06, 06:21 PM posted to rec.aviation.piloting
Right, for aviation fuel you usually get to choose your pre-auth amount
at the pump but not for cars. For credit cards they often only hold $1,
however, I believe the original post was talking about ATM cards. When
I run my ATM at the auto gas station, they require a minimum of $30
account balance or the pump will not turn on.
-Robert
Old June 2nd 06, 03:48 AM posted to rec.aviation.piloting
Really?
Jessica wrote:
$1 vs $150
Just about any gas station that I could buy gas for a Pinto only holds $1.
That includes all of the major oil companies. What filling stations do you
go to that hold more?
Old June 2nd 06, 03:49 AM posted to rec.aviation.piloting
$1 vs $150
Auto Gas: $1
That's exactly right. Sounds like you have an MBNA card for your first
Visa The other companies can tell you what is causing the hold if you
ask their customer service in many cases.
Old June 2nd 06, 04:01 AM posted to rec.aviation.piloting
ATM cards? Holding is not applicable for ATM cards/online debit.
Now if you mean using the Mastercard or Visa logo without a PIN, then holding
is exactly the same as if it was a credit card -- the machine doesn't know
the difference anyway. The OP was warning about using debit cards where
held funds in your checking account can be a real issue.
When
Sounds like your bank's limitation for self service gasoline merchant codes
if you are using offline debit. They have something similar for online
debit.
Old June 2nd 06, 11:58 AM posted to rec.aviation.piloting
You're good! G
It's a credit union card issued by MBNA.
Running dry? Greg Copeland Piloting 257 August 26th 05 03:47 PM
Towing Roger Fowler Soaring 6 August 11th 05 04:25 AM
Replacing fuel cut-off valve with non-a/c part??? Michael Horowitz Owning 46 January 15th 05 10:20 PM
spaceship one Pianome Home Built 169 June 30th 04 05:47 AM
Hot Starting Fuel Injected Engines Peter Duniho Piloting 23 October 18th 03 02:50 AM
