Carb heat. sprung hot or cold?
Old June 1st 06, 12:07 AM posted to rec.aviation.homebuilt
Default Carb heat. sprung hot or cold?
If a carb heat cable breaks, should the position it springs back to be
carb heat on or off?
if its on you dont have full power if a go around is necessary however
if youre landing and carb icing occurs you are safe
if it is off you have full power but are not protected against carb
icing??
Lycoming Carb Heat Mitty Instrument Flight Rules 19 September 21st 05 07:43 PM
Have you ever experienced carb ice with an injector carb? flybynightkarmarepair Home Built 1 January 31st 05 02:48 AM
Induction System Water Problem Mike Spera Owning 1 January 30th 05 06:29 AM
Use of Carb Heat John Kirksey Piloting 4 November 30th 04 08:26 PM
alternate carb heat Ray Toews Home Built 16 October 29th 04 01:41 PM
