Hopefully in the next year or so, my PA22 to Sportsman 2+2 conversion
will be ready for flight. Has anyone have plans or ideas for a simple but dry and functional hangar space.. Really just want to keep it out of the weather with nothing fancy and only enough room for the plane and room to do minor maint. T hanger? Full hangar? Header construction/ideas? all new to me.. thanks in advance.. tj. |
In article .com,
"TJ400" wrote: Hopefully in the next year or so, my PA22 to Sportsman 2+2 conversion will be ready for flight. Has anyone have plans or ideas for a simple but dry and functional hangar space.. Really just want to keep it out of the weather with nothing fancy and only enough room for the plane and room to do minor maint. T hanger? Full hangar? Header construction/ideas? all new to me.. thanks in advance.. tj. Our flying club built a "pole barn" hangar, dirt floor, without a door for 3 AMU's. I will email drawings if interested. |
john smith wrote: In article .com, "TJ400" wrote: Hopefully in the next year or so, my PA22 to Sportsman 2+2 conversion will be ready for flight. Has anyone have plans or ideas for a simple but dry and functional hangar space.. Really just want to keep it out of the weather with nothing fancy and only enough room for the plane and room to do minor maint. T hanger? Full hangar? Header construction/ideas? all new to me.. thanks in advance.. tj. Our flying club built a "pole barn" hangar, dirt floor, without a door for 3 AMU's. I will email drawings if interested. A pole barn is hard to beat for ecoomy and utility. You might consider beefing up one or two roof trusses so that you can use a block and tackle or chainfall for an engine hoist. The rafter space in the joists is also great for storing _light_ stuff. -- FF A lot of airplane stuff for sale he http://groups.google.com/group/rec.a...e=source&hl=en |
wrote A pole barn is hard to beat for ecoomy and utility. Agreed. You might consider beefing up one or two roof trusses so that you can use a block and tackle or chainfall for an engine hoist. Naah. You never beef up the ones in the right place. g Really, if you put a stiffback (a couple 2 x 8's and a 2 x 4, nailed together to make a "U") across 3 or 4 of the trusses (to share the load) a temporary hoist of even a considerable weight will not damage the trusses, at all. -- Jim in NC |
john smith wrote: In article .com, "TJ400" wrote: Hopefully in the next year or so, my PA22 to Sportsman 2+2 conversion will be ready for flight. Has anyone have plans or ideas for a simple but dry and functional hangar space.. Really just want to keep it out of the weather with nothing fancy and only enough room for the plane and room to do minor maint. T hanger? Full hangar? Header construction/ideas? all new to me.. thanks in advance.. tj. Our flying club built a "pole barn" hangar, dirt floor, without a door for 3 AMU's. I will email drawings if interested. would you kindly email drawings please?... not real familiar with a pole barn... I too wasn't counting on installing a door either.. email address is thanks very much.. tj |
On 8 Jun 2006 12:10:44 -0700, "TJ400" wrote:
john smith wrote: In article .com, "TJ400" wrote: Hopefully in the next year or so, my PA22 to Sportsman 2+2 conversion will be ready for flight. Has anyone have plans or ideas for a simple but dry and functional hangar space.. Really just want to keep it out of the weather with nothing fancy and only enough room for the plane and room to do minor maint. T hanger? Full hangar? Header construction/ideas? all new to me.. thanks in advance.. tj. Our flying club built a "pole barn" hangar, dirt floor, without a door for 3 AMU's. I will email drawings if interested. would you kindly email drawings please?... not real familiar with a pole barn... I too wasn't counting on installing a door either.. email address is thanks very much.. tj It depends where you live and the local building codes. Do you need to take snow loads into consideration? A pole barn is just some poles buried in the ground with a wood beam around the top to support the roof trusses. nail 2x4s horizontaly between the poles to give support for the steel siding. It doesn't cost much more to build a full hangar instesd of a T and you will always be able to find stuff to fill the corners. |
It depends where you live and the local building codes. Do you need to take snow loads into consideration? A pole barn is just some poles buried in the ground with a wood beam around the top to support the roof trusses. nail 2x4s horizontaly between the poles to give support for the steel siding. It doesn't cost much more to build a full hangar instesd of a T and you will always be able to find stuff to fill the corners. Yes snow load is a concern... I live in Manitoba Canada.. thanks |
On 8 Jun 2006 14:14:22 -0700, "TJ400" wrote:
It depends where you live and the local building codes. Do you need to take snow loads into consideration? A pole barn is just some poles buried in the ground with a wood beam around the top to support the roof trusses. nail 2x4s horizontaly between the poles to give support for the steel siding. It doesn't cost much more to build a full hangar instesd of a T and you will always be able to find stuff to fill the corners. Yes snow load is a concern... I live in Manitoba Canada.. thanks One good thing about being in Canada is you don't need a building permit to build a hangar at an airport cuz airports are federally regulated. If your local building inspector tries to tell you otherwise just sic COPA on him. You still have to build to accepted standards though. |
("john smith" wrote)
Hopefully in the next year or so, my PA22 to Sportsman 2+2 conversion will be ready for flight. Has anyone have plans or ideas for a simple but dry and functional hangar space.. Our flying club built a "pole barn" hangar, dirt floor, without a door for 3 AMU's. I will email drawings if interested. Maybe not for the Sportsman 2+2, but.... http://makeashorterlink.com/?O3CD25B3D $650 Hangar/Shed - Yahoo Photos (21 pics) Built by one of our EAA chapter members: For Sale (Sold) "Zenair Zodiac 601HDS, taildragger, 45 hrs TTSN, 110 HP Subaru engine, 3 bladed Warp Drive prop, trailered with custom trailer included." Now the Hangar/Shed must go, too. Montblack |
arg, every time I need to find the link for this, it takes me a good 20
minutes of googling to find it. I believe you can go to this website and find free plans that can fit your needs, or at least give you an idea to modify the plans that are there to fit them http://www.ag.ndsu.nodak.edu/abeng/plans/ hundreds of plans, all of them free. if you want them printed they cost, but the pdfs that are available are worth looking at. originally look at them for a homebuilding shop/hangar. eventually I am deciding on just tossing money at it and letting some pole building people do it instead. less time and effort on my part, and it shouldn't increase my debt considerably "TJ400" wrote in message oups.com... Hopefully in the next year or so, my PA22 to Sportsman 2+2 conversion will be ready for flight. Has anyone have plans or ideas for a simple but dry and functional hangar space.. Really just want to keep it out of the weather with nothing fancy and only enough room for the plane and room to do minor maint. T hanger? Full hangar? Header construction/ideas? all new to me.. thanks in advance.. tj. |
| Thread Tools | |
| Display Modes | |
| Late Astronauts Fly In Space Without Medical Certificate | Larry Dighera | Piloting | 46 | February 2nd 06 08:51 PM |
| Hubble plug to be pulled | John Carrier | Military Aviation | 33 | March 19th 04 05:19 AM |
| Rules on what can be in a hangar | Brett Justus | Owning | 13 | February 27th 04 06:35 PM |
| Hangar Space Available at 47N | john price | Piloting | 0 | December 11th 03 01:12 PM |
| Hangar Space Available at 47N | john price | Owning | 0 | December 11th 03 01:08 PM |
