Wing Loadings (was SR22 discussion)
Old June 8th 06, 08:08 PM posted to rec.aviation.piloting
Default Wing Loadings (was SR22 discussion)
SR22 max gross 3400 lbs wing loading 23.5 lb/sqft
PA32-300 max gross 3400 lbs wing loading 19.5 lb/sqft
Bo G33 max gross 3300 lbs wing loading (not found*)
C182R max gross 3100 lbs wing loading 17.8 lb/sqft
PA32-236 max gross 3000 lbs wing loading 17.6 lb/sqft
* neither the G33 POH nor the FAA TCDS contain the wing area nor wing
loading information. If anyone has the information, please add it.
I tried to use the comparable weight aircraft and performance.
As is evident, as a four seater, the SR22 is a "pig".
Although a retract, the G33 Bonanza is a good comparison given its
cruise speed and max gross. It's lower wing loading gives it better
landing preformance.
Useful load may offer a different perspective, but that can vary widely
by individual aircraft, so is not a valid comparison item.
Can anyone provide the gross weight and wing loading for a new Mooney?
Thrusting or Sucking (where's Howard Stern when we need him.) Ken Kochanski (KK) Soaring 37 January 14th 06 10:51 AM
terminology questions: turtledeck? cantilever wing? Ric Home Built 2 September 13th 05 10:39 PM
Marske Flying Wing discussion Group mat Redsell Home Built 0 September 19th 04 02:58 PM
composite wing, wing spars Dave Schneider Home Built 4 May 21st 04 06:35 AM
human powered flight - vertical take off, flexible wing patrick timony Rotorcraft 2 September 18th 03 12:39 AM
