accesory drive adapter oil leak
Old June 14th 06, 03:57 AM posted to rec.aviation.owning
Default accesory drive adapter oil leak
I've got an oil leak on our Aztec left engine, IO540 C4B5. The hydraulic
pump on the left engine has a drain/vent hose that is leaking engine oil. It
is definitely not hyd oil. I had a new garlock oil seal pressed into the
accessory drive adapter housing thinking that this was how the oil was
passing into the hyd pump housing, the old seal was hard as a rock. Tonight
I test flew it for about 20 minutes, operating the flaps and gear as normal.
After landing there were a few oil streaks along the inner main gear door.
After refueling and parking the airplane, there were more streaks and a few
drops dripped from the drain hose.
I popped the inner cowl off and pulled the hyd pump housing drain hose, sure
enough, that's where it was coming from.
Does the garlock seal require some time to absorb oil and expand against the
accessory drive shaft? I've been told both yes and no. I'm hoping that after
a flight or two that the seal will lap itself against the shaft.
Any opinions?
Old June 16th 06, 04:39 PM posted to rec.aviation.owning
the accessory drive shaft? I've been told both yes and no.
Uhh...no
Posted via a free Usenet account from http://www.teranews.com
Old June 16th 06, 05:01 PM posted to rec.aviation.owning
Agreed, and what I'd always thought....after I pulled it off again, I found
the problem. It was leaking through the gasket into the pump. One of the
nuts for the studs is in an impossible position and wasn't torqued
completely, but I finally found a combination of extensions, crow's foot,
and wrench to get it torqued properly. That particular stud happened to
have the pressure oil journal near it.
Bad news was that the fuel pump was also leaking oil, so we had to put a new
fuel pump on it. But it's all fixed now and dry as a bone!
"Fly" fly at icu.net wrote in message
Uhh...no
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 03:55 AM
URGENT HELP !!!...FS2004/Radeon 9700 Probs...... Derek Simulators 21 May 27th 04 10:39 PM
For Sale: Propellor Governor Drive Adapter with Driven Gear John Ammeter Home Built 0 February 1st 04 09:11 PM
