SNAV-LNAV low memory-battery voltage message?
Old June 26th 06, 06:14 AM posted to rec.aviation.soaring
Default SNAV-LNAV low memory-battery voltage message?
Did you check the contacts in the S-Nav? Maybe they
have some corrosion on them, causing the vario to see
lower backup battery voltage.
Steve Leonard
2 S-Navs, 3 L-Navs.
Old June 26th 06, 08:37 PM posted to rec.aviation.soaring
Pardon a dumb question, unit doesn't the unit have to go to Cambridge
and be recertified to be good for conest and badge work? I'm in the
same boat and need the battery replaced. If i can do it myself, all the
better.
Jack Womack
PIK-20B N77MA (TE)
Old June 26th 06, 08:51 PM posted to rec.aviation.soaring
better.
You're mixing up an S-NAV with a GPS-NAV. The GPS-NAV is an IGC
approved flight recorder, if the main portion of the case is opened,
Cambridge (or one of their agents) is required to inspect and reseal the
unit. However, the memory battery in the GPS-NAV can be replaced by the
end user, by removing the top antenna panel. Make sure you follow the
instructions very carefully, or your unit will be making the trip back
to Cambridge. Calibration is also required every 24 months, but any SSA
approved calibration lab can do that.
The S-NAV and L_NAV are flight computers, they have an end-user
replaceable battery for maintaining setup memory. You can just open up
the case, there is no mechanical or electrical sealing...
Marc
Old June 26th 06, 09:30 PM posted to rec.aviation.soaring
Thanks, Marc
JW
better.
Marc
Normal voltage drop Robert M. Gary Piloting 21 January 24th 06 04:44 AM
So I invested my US$6°°.....GUESS WHAT!!!... less than ten days later, I received money [email protected] Owning 1 January 16th 05 07:48 AM
High Voltage Jim Rosinski Piloting 7 October 16th 04 11:48 PM
For Keith Willshaw... robert arndt Military Aviation 253 July 6th 04 06:18 AM
Autorotation ? R22 for the Experts Eric D Rotorcraft 22 March 5th 04 07:11 AM
