I have not been able to use my RST kit headsets with my Val radio.
Transmission is so low as to be unreadable, reception is not a problem. I've used the headsets with a Micro Air transceiver, a Collins and a Icom handheld and the headsets work fine with these radios. At present I am using a loaned ASA Air Classics HS1 headset with the Val and am transmitting loud and clear, the Val also transmitted fine using a loaned David Clark H40 headset. Has anyone had any experience, good or bad, with this radio-headset combo? Any ideas? |
"Stew Hicks" wrote in message news:jxwog.105250$IK3.30843@pd7tw1no... I have not been able to use my RST kit headsets with my Val radio. Transmission is so low as to be unreadable, reception is not a problem. I've used the headsets with a Micro Air transceiver, a Collins and a Icom handheld and the headsets work fine with these radios. At present I am using a loaned ASA Air Classics HS1 headset with the Val and am transmitting loud and clear, the Val also transmitted fine using a loaned David Clark H40 headset. Has anyone had any experience, good or bad, with this radio-headset combo? Any ideas? Somehow I bet this one is for Jim. Paging Jim Weir grin |
Stew Hicks wrote: I have not been able to use my RST kit headsets with my Val radio. Transmission is so low as to be unreadable, reception is not a problem. I have had the oppisite problem. If I do not speak softly the Val is overmodulated and garbled. Lyn |
wrote in message oups.com... Stew Hicks wrote: I have not been able to use my RST kit headsets with my Val radio. Transmission is so low as to be unreadable, reception is not a problem. I have had the oppisite problem. If I do not speak softly the Val is overmodulated and garbled. Lyn You are using RST headsets?? |
You are using RST headsets?? Yes, they may be an earlier version, have had them about 14 years. Lyn |
"Stew Hicks" wrote in message news:jxwog.105250$IK3.30843@pd7tw1no... I have not been able to use my RST kit headsets with my Val radio. Transmission is so low as to be unreadable, reception is not a problem. I've used the headsets with a Micro Air transceiver, a Collins and a Icom handheld and the headsets work fine with these radios. At present I am using a loaned ASA Air Classics HS1 headset with the Val and am transmitting loud and clear, the Val also transmitted fine using a loaned David Clark H40 headset. Has anyone had any experience, good or bad, with this radio-headset combo? Any ideas? |
| Thread Tools | |
| Display Modes | |
| Headset Noise | Jonathan Goodish | Owning | 31 | April 19th 06 02:18 PM |
| ICOM Headset Adaptor Plug | Ron Wanttaja | Home Built | 3 | June 2nd 05 08:54 AM |
| Panther C.A.T. headset. | Ross Taylor | Products | 0 | October 23rd 04 12:59 AM |
| Bose makes good on my wife's headset. | Kyler Laird | General Aviation | 3 | March 10th 04 03:08 PM |
| Bose makes good on my wife's headset. | Kyler Laird | Piloting | 3 | March 10th 04 03:08 PM |
