Scenario 1....
Severe clear weather from point A to point B going east. MRA is 7000 in which part of this area is below ATC radar coverage from past experience. Highest OROCA enroute is 2600, filing is direct from airport to airport. If I filed "VFR on top" /G for 3500, would I be legal to file this plan since I would be able to maintain visual flight rules (VFR)? Scenario 2..... Throw in an active MOA to the above. I would assume that I would get vectors or an amended clearance around the active MOA even though I am "VFR on top". Would this be a correct assumption? Allen |
A Lieberman wrote: If I filed "VFR on top" /G for 3500, would I be legal to file this plan since I would be able to maintain visual flight rules (VFR)? Doesn't /G nullify the MRA? |
On Sat, 01 Jul 2006 03:15:42 GMT, john smith wrote:
In article , A Lieberman wrote: If I filed "VFR on top" /G for 3500, would I be legal to file this plan since I would be able to maintain visual flight rules (VFR)? Doesn't /G nullify the MRA? I'd suspect so John, EXCEPT if I have to join a victor highway via VOR or intersection via VOR radials especially if scenario two panned out with a hot MOA. Allen |
I'd suspect so John, EXCEPT if I have to join a victor highway via VOR or intersection via VOR radials especially if scenario two panned out with a hot MOA. MRA is minimum RECEPTION altitude, presumably for the primary navaid. It's primarily a physics thing, not a legal thing. GPS is not the primary navaid, but can substitute, so you can navigate (even on the ground) using GPS along VOR radials or Victor Airways. I don't know the answer to the original question though. Jose -- The monkey turns the crank and thinks he's making the music. for Email, make the obvious change in the address. |
In a previous article, said:
Scenario 2..... Throw in an active MOA to the above. I would assume that I would get vectors or an amended clearance around the active MOA even though I am "VFR on top". Would this be a correct assumption? VFR is not prohibited in active MOAs, just discouraged. I would suspect that they'd let you blunder on through in that situation. -- Paul Tomblin http://xcski.com/blogs/pt/ "To announce that there must be no criticism of the president, or that we are to stand by the president, right or wrong, is not only unpatriotic and servile, but is morally treasonable to the American public." -- Teddy Roosevelt |
"A Lieberman" wrote in message ... Scenario 1.... Severe clear weather from point A to point B going east. MRA is 7000 in which part of this area is below ATC radar coverage from past experience. Highest OROCA enroute is 2600, filing is direct from airport to airport. If I filed "VFR on top" /G for 3500, would I be legal to file this plan since I would be able to maintain visual flight rules (VFR)? You can legally file anything, the question is can you legally be issued what you've filed. VFR-On-Top is still an IFR operation and all of the Instrument Flight Rules apply to it with the exception of § 91.179 IFR cruising altitude or flight level which directs pilots operating VFR-On-Top to comply with § 91.159 VFR cruising altitude or flight level. You still have to comply with § 91.177 Minimum altitudes for IFR operations. Filing VFR-On-Top does not relieve ATC of the requirement to assign routes on airways or within normal navaid usable limits if radar monitoring cannot be provided. If you're assigned an airway while VFR-On-Top the lowest altitude you can use is that which conforms to § 91.159 and is at or above the MEA. Why do you want to do this anyway? In areas below radar coverage VFR-On-Top has nothing to offer. You aren't provided any separation or traffic advisories but you're still tied to a route. Why not just go VFR? Scenario 2..... Throw in an active MOA to the above. I would assume that I would get vectors or an amended clearance around the active MOA even though I am "VFR on top". Would this be a correct assumption? Yes. |
"Paul Tomblin" wrote in message ... VFR is not prohibited in active MOAs, just discouraged. I would suspect that they'd let you blunder on through in that situation. VFR-On-Top is an IFR operation. FAA Order 7110.65R Air Traffic Control Chapter 9. Special Flights Section 3. Special Use and ATC Assigned Airspace 9-3-3. VFR-ON-TOP If the aircraft's route, track, or altitude may cause it to enter an active Prohibited/Restricted/Warning Area, MOA, or ATCAA: a. Inform the pilot to conduct flight "VFR-on-top" at least 500 feet above the upper limit or lower limit of the airspace (subject to para 7-3-1, VFR-on-top); or PHRASEOLOGY- MAINTAIN VFR-ON-TOP AT LEAST 500 FEET ABOVE/BELOW (upper/lower limit of airspace) ACROSS (name or number of airspace) BETWEEN (fix) AND (fix); and if the airspace is an ATCAA, (name of ATCAA) IS ATC ASSIGNED AIRSPACE. REFERENCE- FAAO 7110.65, Class A Airspace Restrictions, Para 7-1-1. b. Clear the aircraft via a routing which provides approved separation from the airspace. c. Exception: Some Prohibited/Restricted Areas are established for security reasons or to contain hazardous activities not involving aircraft operations. The addition of 500 (or 1,000) feet to the upper/lower limit of these Prohibited/Restricted Areas is not required if the areas have been identified by facility management. REFERENCE- FAAO 7210.3, Prohibited/Restricted Areas, Para 2-1-17. |
On Sat, 01 Jul 2006 13:37:40 GMT, Steven P. McNicoll wrote:
Why do you want to do this anyway? In areas below radar coverage VFR-On-Top has nothing to offer. You aren't provided any separation or traffic advisories but you're still tied to a route. Why not just go VFR? First of all, thanks for the reference on my question as it answered it perfectly. I was planning a flight from KMBO to KEDN today. Several reasons why I wanted to do the original scenerio. Winds aloft from 3,500 to 5000 made for a 15 minute difference in flight time. Had I gone to 7000 feet to ensure radar coverage, it would have added another 5 minutes. With passengers, that extra 20 minutes would have been significant difference. Going the victor highways would have added about 20 minutes as compared to direct. Most importantly, I love the second pair of eyes for traffic advisories. Sure, I could do flight following VFR, but since I am already in the system, might as well stay in the system without the risk of being dropped. And the most fun of it all, it's nice to see my flight path at http://flightaware.com/live/flight/N...752Z/KMBO/KEKY when I return home. Another way of keeping track of my flight time :-) Website doesn't track VFR flight following too well. As it turned out, couldn't launch today as I think something went south with my starter or whatever engages the propeller (Bendex?) Allen |
"A Lieberman" wrote in message . .. Several reasons why I wanted to do the original scenerio. Winds aloft from 3,500 to 5000 made for a 15 minute difference in flight time. Had I gone to 7000 feet to ensure radar coverage, it would have added another 5 minutes. With passengers, that extra 20 minutes would have been significant difference. Going the victor highways would have added about 20 minutes as compared to direct. Most importantly, I love the second pair of eyes for traffic advisories. Sure, I could do flight following VFR, but since I am already in the system, might as well stay in the system without the risk of being dropped. I still don't get it. If you have to go to 7000 to ensure radar coverage then that's how high you'd have to go for that second pair of eyes. If you're high enough to ensure radar coverage you're high enough to be cleared direct. |
On Sat, 01 Jul 2006 16:41:31 GMT, Steven P. McNicoll wrote:
I still don't get it. If you have to go to 7000 to ensure radar coverage then that's how high you'd have to go for that second pair of eyes. If you're high enough to ensure radar coverage you're high enough to be cleared direct. The radar outage would only be for a small segment of the flight. Why go so high when I don't need to. Not quite sure why the outage, since it happens right around the MEI airport who has approach controllers but it does. Terrain isn't a factor since it's flat as a board. Now, I probably could request 7000 for that short period of time when I expect out of radar contact, but by the time I climbed to 7000 feet the time gained in flying the lower altitude would be lost in the climb to 7000 feet. In other sectors, I have flown outside of radar coverage, but had to report when a certain distance of a VOR, but this particular sector doesn't work this way. Bottom line for "flight planning purpose" I am only out of the second pair of eyes for a very short duration of the flight. It was more efficient to select a lower altitude for passenger considerations and lose the second pair of eyes in a part of the trip where traffic is very minimal at best. So, I'd be willing to give up 20 minutes of non radar coverage for a more direct and quicker flight. If I was by myself, this all would have been a moot point as I would just fly the victor highways. Allen |
| Thread Tools | |
| Display Modes | |
| Lyc. O-360 cylinder question | JB | Owning | 13 | November 27th 04 10:32 PM |
| Handheld battery question | RobsSanta | General Aviation | 8 | September 19th 04 04:07 PM |
| A question on Airworthiness Inspection | Dave S | Home Built | 1 | August 10th 04 06:07 AM |
| Question | Charles S | Home Built | 4 | April 5th 04 10:10 PM |
| Partnership Question | Harry Gordon | Owning | 4 | August 17th 03 12:23 AM |
