Winch for Sale - U.S.
Old July 10th 06, 06:11 PM posted to rec.aviation.soaring
Bob Lacovara
Default Winch for Sale - U.S.
Winch for Sale - U.S. (Pennsylvania)
Philadelphia Glider Council is selling a 350 Chevy based winch with
4500 ft. of relatively new high tensile rope. Capable of launching a
max gross Grob 103 to 1200 ft with 3600 ft of cable out. Complete with
chute and rigging - ready to go. $5,000 USD. Contact Jack Goritski -
for photos and complete details.
Old July 11th 06, 07:23 PM posted to rec.aviation.soaring
Jim Vincent
"Bob Lacovara" wrote in message
If it can launch a max Gross G103, then what was the rationale spending $20k
on a new one?
Old July 11th 06, 07:29 PM posted to rec.aviation.soaring
Marc Ramsey
Jim Vincent wrote:
"Bob Lacovara" wrote...
on a new one?
What kind of "new" winch did they get for $20K?
Old July 11th 06, 07:46 PM posted to rec.aviation.soaring
Jim Vincent
" What kind of "new" winch did they get for $20K?
http://www.pgcsoaring.org/Opening%20Day%202006.htm
Club Winch Club Equipment
Two Drum Eagle Winch - Truck Mounted
455 Oldsmobile
Auto transmission
4500' Spectra rope
Tost rigging
Old July 11th 06, 07:56 PM posted to rec.aviation.soaring
Marc Ramsey
455 Oldsmobile
Auto transmission
4500' Spectra rope
Tost rigging
Nice winch, I was tempted by that one myself...
Old July 12th 06, 04:26 PM posted to rec.aviation.soaring
Jim Vincent
Jim's question seems a bit silly since he actually knows the whole
story--but an answer is in order. PGC has successfully used the single
drum winch for sale to launch full gross Grobs on many ocassions (Dean
Carswell conducted 30+ training filights on it one weekend--all dual in
Grob 103s). With 3600 feet of rope out, however, and retrieve over
less than perfecly smooth ground, our turn around time is excessive for
a large club with 120 members. The dual drum winch can make a big
difference in the number of operations per hour--simple logic, but I
guess we must mention it.
Of course the extra power of the newer winch is nice to have, to say
nothing of the fact that the newer winch is mounted on a roadable truck
bed.
If you are interested in this winch contact Jack as noted in the
initial post. I suspect that we will all see more ground launches as
the cost of av fuel reaches new highs.
Fly safe--
Skip Guimond
Hey Skippy! Regarding the whole story, I have heard many of you esteemed
PGC demi-gods say that the old winch is underpowered and inadequate for
towing the G-103. I always maintained that it was just fine if you knew to
transition your climb properly. Maybe you finally learned to do that
properly?
Regarding value of the dual drum winch, my friends and I used to do about
5-6 snaps per hour off that single drum. Watching you guys, you were lucky
to get two an hour. The dual winch can't make up for your silliness. But
when you have money to burn from the high entrance fee and 40-50% turnover
every two years, what the heck, spend the money. After all, you guys are
the premier glasshole establishment on the East coast with a 60 year
history, blah, blah, blah. Never mind that the money was never approved by
the membership to go buy the winch.
Regarding buying the old winch, be very careful. PGC had an agreement to
sell that winch to a partnership and then renigged on the deal, wanting more
money. One of the members of that partnership had donated the engine for
the winch and the partnership had done about 90% of the work of getting that
winch up and running. That is goodwill for you.
Old July 12th 06, 07:06 PM posted to rec.aviation.soaring
Wallace Berry
In article .com,
bed.
Fly safe--
Skip Guimond
I was the main winch driver for the Southern Eagles Club where the Eagle
winch originated (designed and built by Glen Lawler in Auburn, AL). I've
probably driven more launches with it than anyone. The difference
between a good winch and all the rest is in ease of use and reliability.
The Eagle winch is very easy to use and has been extremely reliable. The
only problems we ever encountered with it was the guillotine blades got
loose after 2000 launches and clipped off a cable splice, and once when
we had a simulated cable break, I didn't get on the brakes fast enough,
causing a cable tangle that got out of the drum and wiped out a brake
line. The Spectra line is the way to go. It doesn't throw a tangle the
way steel cable does. The winch was really still in the prototype stage
when we started using it and Glen never got around to finishing the
mechanism for selecting the left or right drum from inside the cab. You
have a great machine, I hope you get a lot of good use out of it. I miss
it still.
Wallace
Old July 12th 06, 08:33 PM posted to rec.aviation.soaring
Jim Vincent
"Wallace Berry" wrote in message
In article .com,
The difference
Wallace,
You make a very good point here. In the past, that winch was very
reliable...we never had a problem that we could not fixed or affected winch
launch safety. As long as you have someone that can change the oil
occasionally and do minimal maintenance. THAT must be why PGC is selling
it; everyone who knows anything about working on it has quit! Let's see...
Head of "green thing" maintenance (the four wheel ATVs)...quit
Head of field maintenance...quit
75% of maintenance committee...quit.
Who is left? Oh yeah....Jack! The Princeton graduate who never went to
Princeton? The Engineer who cannot comprehend a gear warning circuit? The
A&P who doesn't have an A&P but tells everyone that he does? The guy who
mixes epoxy in Wawa coffee cups and then installs flight surfaces on
aircraft? The one that falsifies log book entries? Yeah, that's the one!
Sure, touch base with him and I'm sure he'll tell you how wonderful the
winch is and how perfectly he has maintained it. Be sure to look under the
seat when you get the winch for your lucky surprise. So far I've found
tools under two seat pans of gliders that Jack has worked on.
Old July 12th 06, 11:12 PM posted to rec.aviation.soaring
JD[_1_]
We've run across this guy Vincent or Hussain, whatever his name is now,
at the Ridge. At one point he was bending my ear about techniques for
flying my new Discus 2b, only to find our he'd never flown one. It
seems the he spreads disconcert and ill-will in a number of locations.
I know some of the people at PGC and they run a first-class operation
and have good equipment. I incidentally spoke with Dean Carswell after
he did the winch course at PGC and he said the operation ran well. I
suspect every club has, or has had, a malcontent outsider who has
nothing good to say. I had to deal with a couple of these personalities
at my former club. The tone of Vincent's comments makes it clear that
he has a axe to grind and I take his foul-mouthing with a grain of
salt.
My thought is that we should be doing more winching in the U.S. and if
this functional winch for sale can help a soaring group get started
that is a benefit. From the looks of it, it appears PGC made a good
choice in buying the new winch. Notwithstanding Mr. Vincents venom,
good luck with the new machine.
JD
In article .com,
The difference
Wallace,
Old July 13th 06, 02:43 PM posted to rec.aviation.soaring
I thought Lenny was gone for good!! When did he move east?
snip
Winch operations Edward Winchester Soaring 7 April 13th 06 11:24 AM
Winch give-away KP Soaring 6 January 11th 05 08:04 PM
Winch design c1rrus Soaring 10 January 19th 04 12:18 PM
Winch Way Is Up !! Craig Freeman Soaring 45 November 6th 03 03:08 PM
using winch instead of aerotow goneill Soaring 5 August 27th 03 02:46 PM
