I intend to buy a handheld.
Old July 20th 06, 08:17 PM posted to rec.aviation.piloting
almostthere[_1_]
Default I intend to buy a handheld.
Just got my ticket and I plan to purchase a handheld Nav-Comm for back-up
but it is said that they're useless at altitude without an external antenna
connection. What connector do I use (BNC?) and how do I go about doing this
on rented C172s? Any alternatives/suggestions? Thanks in advance.
Old July 20th 06, 09:15 PM posted to rec.aviation.piloting
john smith
In article t,
Tthe connectors on the patch cord from the radio to the external antenna
will depend on what radio you purchase. Not all radios have BNC
connectors.
Old July 20th 06, 09:52 PM posted to rec.aviation.piloting
Jim Macklin
The rubber ducky antenna will work at altitude, just not as
well as an external antenna. I have used a King KX99 at
35,000 feet in King Air to talk to Center and the same King
KX 99 from a Bonanza below 3000 AGL to talk to FSS and tower
for landing clearance.
If you rent, the owner is not going to want you breaking his
antenna harness.
James H. Macklin
ATP,CFI,A&P
"john smith" wrote in message
| In article
t,
an external antenna
go about doing this
in advance.
external antenna
have BNC
| connectors.
Old July 21st 06, 02:15 AM posted to rec.aviation.piloting
BTIZ
they work great for talking.. just not so great for nav reception
get the ICOM A6(comm only) or A24(comm/nav)
BT
"Jim Macklin" wrote in message
news:l3Svg.78950$ZW3.64979@dukeread04...
antenna harness.
James H. Macklin
ATP,CFI,A&P
| In article
t,
an external antenna
go about doing this
in advance.
external antenna
have BNC
| connectors.
Old July 22nd 06, 02:14 AM posted to rec.aviation.piloting
Jeff Shirton
I can just see it now...
4000 ft, pilot contacts tower...
ATC: Pilot, what are your intentions?
Pilot: I intend to buy a handheld.
Jeff Shirton (PP-ASEL) jshirton at cogeco dot ca
He didn't sound like a baseball player... He said things like,
"Nevertheless", and "if, in fact." - Dan Quisenberry on Ted Simmons
Challenge me (Theophilus) for a game of chess at Chessworld.net!
Old July 20th 06, 11:43 PM posted to rec.aviation.piloting
Robert M. Gary
Use the suction cup antenna that came with your radio.
-Robert
Old July 21st 06, 12:17 AM posted to rec.aviation.piloting
My handheld has been used from 6 miles out with no external antenna and
worked just fine.
Old July 21st 06, 03:28 AM posted to rec.aviation.piloting
worked just fine.
"Robert M. Gary" wrote:
That doesn't sound very useful. 6 miles is a pretty short distance to
try to raise Center.
I didn't say that was the maximum distance it works w/o an antenna ...
it may well have a much further range. That's just the furthest I know
for a fact that it worked fine w/no antenna.
Old July 21st 06, 02:16 AM posted to rec.aviation.piloting
BTIZ
I've stood on the ground and talked to an aircraft 20 miles away..
air to air is even better.
BT
back-up
antenna
this
worked just fine.
Getting the MOCA Dan Instrument Flight Rules 59 July 3rd 06 01:43 AM
More IFR with VFR GPS questions Chris Quaintance Instrument Flight Rules 58 November 30th 05 08:39 PM
Navcom - handheld VS panel ? [email protected] Home Built 10 October 31st 05 08:08 PM
Upgrade handheld GPS, or save for panel mount? [email protected] Owning 7 March 8th 04 03:33 PM
Ext antenna connection for handheld radio Ray Andraka Owning 7 March 5th 04 01:10 PM
