Buying prop strike engine
Old August 7th 06, 12:53 AM posted to rec.aviation.homebuilt,rec.aviation.owning
Default Buying prop strike engine
http://www.whiteindustries.com/
White Industries lists engines with flange runout. What does flange
runout tell about the engine?
It seems some prop strike engines have a larger flange runout reading
than others, and the larger the flange runout, the lower the price.
Why?
Thanks.
Old August 7th 06, 01:36 AM posted to rec.aviation.homebuilt,rec.aviation.owning
Newps
Flange runout means absolutely nothing. Especially on Lycomings.
Because of the meatllurgy involved they don't bend, they break.
Why?
Thanks.
Old August 7th 06, 01:49 AM posted to rec.aviation.homebuilt,rec.aviation.owning
Why?
The higher the runout number, the more damage there is to either the
crank or the case. It depends on the exact engine series as to how bad
a number you can tolorate before the repair costs are closing in on
replacement costs.
For me, it's not worth dealing with an engine that has had a prop
strike unless one of two things are known:
1: The prop strike was with a wooden prop or
2: The case has already been through a complete inspection and the shop
is able to guarantee that the case has no damage, visable or hidden,
and that the case will meet or beat the table of limitations the
manufacturer has for that engine.
Craig C.
Old August 8th 06, 04:14 PM posted to rec.aviation.homebuilt,rec.aviation.owning
abripl[_1_]
1: The prop strike was with a wooden prop or...
Some composite props, like IVO, break easy on impact. I had a prop
strike with IVO and had the crank magnafluxed. No flange runout or
cracks were found. I have a Franklin 6A350 engine (are they more
solid?).. It's the aluminum rigid props that are crank killers.
SQ2000 canard http://www.abri.com/sq2000
Old August 9th 06, 09:43 PM posted to rec.aviation.homebuilt,rec.aviation.owning
You're taking your chances either way. A few years ago I met a guy
at a Montana backcountry strip that was taking his wings off and
putting his Champ on a flatbed truck. Seems his crank snapped in
flight and he was lucky enough to be within gliding distance of a
usable strip. He had taxied his plane into a snowbank a few months
earlier. It stopped the engine, but hadn't damaged the prop, so he
assumed everything was OK. That assumption nearly killed him and his
passenger a few months later.
Prop damage or flange runout doesn't tell you anything about possible
cracks in the crank.
Old August 10th 06, 02:46 PM posted to rec.aviation.homebuilt,rec.aviation.owning
abripl[_1_]
If he hadn't run into the snow bank is there a guarantee that the crank
was OK? Aren't there faulty cranks for other reasons and it could have
been a coincidence? Also did he have an aluminum prop?
...............................Seems his crank snapped in
Lou
If your going to rebuild anyway, take a look at these.
http://www.airboattrader.com/PartsForSale.htm
Lou
Old August 7th 06, 02:50 AM posted to rec.aviation.homebuilt,rec.aviation.owning
Guy Byars
Great site, I especially like the 8 cylinder Contential:
http://www.airboattrader.com/PartsF1420.jpg
"Lou" wrote in message
Lou
Old August 7th 06, 04:50 PM posted to rec.aviation.homebuilt
OK, if you're not going to buy a certiifed engine, then
what are the pros and cons of buying an airboat
engine vs a VW or Corvair conversion?
FF
Old August 8th 06, 02:36 PM posted to rec.aviation.homebuilt
Bret Ludwig
One, the airboaters are getting rid of the LyCon aircraft engines in
droves. That should tell you something.
Two, VWs are too small to be used as a direct drive airboat plant. A
direct drive VW is good only for motorgliders, drones, and the very
minimal single seat aircraft. Geared (or belted) VWs might be okay but
none are ever seen. Corvairs are proving crank breakers when operated
(direct drive) at power levels much over that of the old Pietenpol
conversions.
In my opinion there are only two ways to fly unless you have warbird
money: a certified aircraft engine in a certified airframe or a
homebuilt with an en-bloc-construction, liquid cooled general purpose
engine with belt or gear reduction. VWs, two strokes and the like are
just not powerful or dependable enough, noncertified "aircraft" designs
like the Jabiru are a worst of both worlds and vastly overpriced scam,
and LyCon aircraft engines are overpriced museum pieces if you don't
need a certificated engine.
Buying prop strike engine [email protected] Owning 18 August 14th 06 12:47 AM
Engine Balancing and Resonance Vibration Problem AllanFuller Owning 13 September 12th 05 12:51 AM
Towing Roger Fowler Soaring 6 August 11th 05 04:25 AM
Prop Feathers and Engine Shuts down after landing???????? AIR ADVENTURE82 Piloting 3 August 21st 03 05:42 AM
