Vacuum pump STC
Old August 13th 06, 05:41 PM posted to rec.aviation.piloting
gt
Default Vacuum pump STC
I would like to make my 1960 Cessna 172A IFR. Currently, I have only
venturi vacuum. My A & P stated that as there is no STC for a vacuum
pump intall, I need a form 337 field approval...I think it is form 337,
I could be wrong on that. Does anyone have information relating to
STC's and field approvals for vacuum pump installations on a
Continental 300-C?
Old August 13th 06, 06:28 PM posted to rec.aviation.piloting
Stache
Continental 300-C?
In short there is a way to do this.
If there is no STC for your make and model a FAA Form 337 Major
Alteration/Major Repair is the only way to go. There is a simple way
to have the vacuum pump field approved. First find a STC to install a
vacuum pump, then contact the STC holder and tell them that you want to
install the vacuum pump on your make and model and will be using the
field approval process. Request they provide you with a letter of
"No Objection" to use their STC. With this letter in hand have the
A&P write up a Form 337 using all the data on the STC and do NOT call
out the STC number or reference to it, just recite all the data.
Submit the Form 337 to your local FSDO for approval. The FSDO will
sign off in block 3 of the From 337 then you can install it as approved
data. I have done this several times in the past.
It cost the STC holder a lot of money to add a make and model aircraft
to the STC so many will allow you to use their data if you purchace the
material from them.
Stache
Old August 13th 06, 07:44 PM posted to rec.aviation.piloting
Jim Carter[_1_]
-----Original Message-----
Posted At: Sunday, August 13, 2006 10:41 AM
Posted To: rec.aviation.piloting
Conversation: Vacuum pump STC
Subject: Vacuum pump STC
337,
Continental 300-C?
When I converted my Funk B-12 from a 15A generator to a 60A alternator,
all we had to do was file a form 337 and make the appropriate logbook
entries to show that we had complied with the similar installation on
the Cessna 150. (It also uses the O-200 / C85 engine core.)
I also built up a new bus and electrical sub-system to handle the
additional load.
I would expect you could do something similar.
Wet vs Dry Vacuum Pump Fastglasair Owning 7 December 18th 04 12:46 AM
Wet vs Dry Vacuum Pump Fastglasair Home Built 1 December 15th 04 06:17 PM
Backup vacuum pump system STC'ed for Cherokee 180 Chuck Owning 6 September 18th 04 03:30 PM
Wet Vacuum Pump smackey Owning 6 February 24th 04 08:03 PM
Battery and Vacuum pump PaulaJay1 Owning 3 January 16th 04 05:22 PM
