squealing Plantronic mic
Old August 16th 06, 01:50 AM posted to rec.aviation.soaring
Default squealing Plantronic mic
Howdy,
Has anyone experienced a squealing plantronics headset mic? Ours was
replaced by the company and started squealing again. It is hooked into
a Becker 4201 which was tweaked by the factory as a troubleshooting
measure. It seems like the mic is being affected by the antenna RF. If
I hold it below the cockpit outside, it improves. Used to work just
fine. Don't know what happened. Any ideas?
BTW, the side tone is turned off.
Tim
Old August 16th 06, 02:52 AM posted to rec.aviation.soaring
Bob Kuykendall
The last time I had this problem (with a homemade Les Sebald-designed
clip-on mic), I search high and low in the mic circuit and didn't find
the problem. It turned out that it was caused by a bad connection in
the antenna cable. The problem went away when I cleaned all the BNC
connections and the antenna ground terminal attachment.
Just a thought. Good luck!
Bob K.
Old August 18th 06, 02:56 AM posted to rec.aviation.soaring
qflyer1
Thanks, Bob. I'll give the connections a good going-over and see what
happens....
Cheers,
Tim
Bob K.
Old August 18th 06, 04:56 AM posted to rec.aviation.soaring
Tony Verhulst
Howdy,
Around here, they never live that long. We hate stoolies.
Tony V.
Old August 18th 06, 03:22 PM posted to rec.aviation.soaring
COLIN LAMB
Mike problems could be caused by the antenna as Bob suggests, or it could be
caused by a ground loop.
A ground loop in the mike circuit might occur if there is more than one
grounding point - for example where the shielded mike cable is grounded at
the radio and also grounded at the metal panel where the mike connector is
mounted.
Sometimes simply insulating the mike connector from the panel will cure the
problem.
Colin
