My annual inspection on the Ercoupe was due in June. What I usually do is
take the plane to the inspector late in the month and then he usually signs/dates it the next month so I get close to 13 months between annuals. So, I took my plane from Fairmont (FRM) to Jackson (MJQ) on June 30th expecting to get it inspected the first part of July and have it back for the many fly-in breakfasts during July and August. So much for that plan. When I last fueled up before taking it over for the annual, I saw in the left wing tank that one of the baffle/ribs had fallen down inside the tank and just laying on the bottom. I mentioned this to the mechanic/inspector and he said it would need to be repaired or replaced before he'd sign off the annual inspection. He called me a couple days later and said my options were to get the tank repaired or find a replacement and he had found refurbished replacements for around $1,600 or he could send my tank in someplace to repair for around $500. Plan A: I called up Wentworth Aircraft in Minneapolis and they said they had an Ercoupe tank in stock for $495. I told them I'd stop by and pick it up the next day; saving the shipping costs and time(?). I drove from Fairmont to Minneapolis and got to Wentworth at lunchtime. The salesman I talked with about the tank was out for lunch and no one else knew much about it. I waited around for the salesman and got the tank and drove it back to Jackson. This was on a Friday and by the time I got to the Jackson airport, the mechanic wasn't there but I left the tank there. The mechanic called me on following Monday morning saying the tank I got at Wentworth had sloshing compound used on it and that he wouldn't put it on my plane. I guess I should have checked the tank closer when I got it from Wentworth... Plan B: During that week I had exchanged E-mails with Montblack about my Ercoupe tank issue and he mentioned Roger Dufresne in Forest Lake that repairs Ercoupe tanks. Great! I went over to Jackson and picked up the Wentworth tank and assisted the mechanic with taking the original tank off. I took both tanks up to Minneapolis to return the one to Wentworth and repair the original one. I talked with Roger about repairing the tank and he said he's repaired a few of them but wanted me to get some fuel tank sealant. I found the sealant listed in Aircraft Spruce but needed it quickly. I checked a few places here in Fairmont and also stopped at a fuel tank (storage tanks) place in Mankato on the way to Minneapolis and no one had the sealant. This was on a Friday and I was going to meet Roger on Saturday to work on the tank. After dropping the Wentworth tank off and getting a refund, I drove up to Anoka County airport and gave Montblack a call. He said he could come over to the airport to meet me and offered me a place to stay overnight. When Montblack arrived, he showed me around the airport and I mentioned about the sealant I was trying to find. We stopped at one of the hangars where he knew some guys working on a Howard and we talked with them and they had some sealant in stock that we could borrow and replace on Monday (called a place in Brooklyn Park that had the sealant but couldn't make it over there before it closed). I had recognized the Howard (and the pilots) as the one that flew into Fairmont a couple years ago. Nice guys! On Saturday, Montblack and I went up to Forest Lake to get the original tank repaired. Met with Roger in Forest Lake and he said he had worked on the aluminum tanks that were riveted but hadn't worked on the terneplate style tank that I had that was soldered. He got the endplate of the tank unsoldered and got the baffle/rib back in place but then ran into problems getting the endplate soldered back on. He suggested taking it to a metal shop and getting a new endplate fabricated that could be riveted in and use the tank sealant. Plan C: I took the tank back to Fairmont and stopped at the first metal shop that I knew and he said he wouldn't touch it. He suggested the local heating/plumbing shop so I took it over there. I know the owner of the plumbing shop (fellow local pilot) and asked him if he could fabricate a new endplate. He said he was busy with air-conditioning calls (Minnesota heat wave in July) and would get back to me when he got it done. I kept calling on him every few days to see how he was coming on repairing the tank. I had hoped he would have it completed before he left for a few days at Oshkosh, no luck. When he got back from Oshkosh, I talked with him and he had a new endplate cut but wasn't able to bend it around the curved part with the tools he had and suggested another metal shop. I took the tank, the original endplate, the new unbent endplate piece and some tank sealant to the 3rd shop. He called me a few days later and said it was ready. I picked it up and paid him $125 for the repair. He had used the original endplate and got it silver soldered back on and said he pressure tested it. I drove the tank over to Jackson and the mechanic looked at it and said it looked OK but needed to be cleaned out and handed me a hose. I filled the tank with water and the endplate started leaking! Not a good thing. I guess it was good that we checked it before mounting it on the plane. I took it back to the 3rd metal shop and told him it leaks. I stopped by there a few days later and he had the tank ready, again. I took the tank home, filled it with water -- no leaks, on the repaired endplate! Last Wednesday, I tried to call the mechanic in Jackson to say the tank was ready but he wasn't around. Found out he had flown to Wisconsin and was weathered in someplace on his way back. He finally called me back Monday and said I could bring the tank over on Tuesday morning and assist on putting it back on. Ok, I figured I'd drive the fuel tank over, help him put it back on, fly the plane back to Fairmont and then get a ride back to Jackson to get my car. We mounted the tank onto the wing and I suggested that we check for leaks before putting all the fairings, floorboard and panels back on. I filled up 2 gas cans with $40 worth of avgas and put that in the tank. The endplate didn't leak, but the quick drain did... Ok, drain the fuel back into the gas cans, replace the o-ring in the quick drain and try it again. This time NO LEAKS. I helped put the faring back on (a 2 person job) with me standing on my head inside holding the ny-lock nuts while he tightened the screws from the outside. I reinstalled the floorboards, attached the brake pedal (glad I don't have the rudder pedals!) and got the inside completed while he finished up the hardware on the outside. He had replaced the landing gear donuts and the fuel floats (the old cork floats wouldn't float anymore) a couple weeks ago and just needed the tank installed before signing off the inspection. Done. With the replacement of the donuts and floats while in for inspection, it ended up costing 1 AMU. It was getting late on Tuesday and I was beat from standing on my head in the cockpit most of the day. I had the choice of flying in the heat of the day back to Fairmont and be carless the rest of the day until I could get a ride back to Jackson to get my car or just driving back and get a ride back to Jackson on Wednesday. Some things I've found out about Ercoupe fuel tanks. There are different types depending on the S/N of the aircraft. Around serial number 813, they changed the landing gear configuration and the fuel tanks for under that number need a 'notch' in the tank for the gear. The ones after S/N 813 are straight across the back edge and are usually aluminum and riveted together. The older terneplate style ones (like mine with the 'notch') are stainless steel (or alloy?) with part of it riveted and part silver soldered. The tank that I had picked up at Wentworth was the 'new' style anyways and wouldn't have fit even if it didn't have the sloshing compound problem. I have been calling all over the country the past month getting information on tanks and trying to find a replacement that will fit my under 813 Ercoupe. I have found several places that have Ercoupe tanks, either for higher serial numbers or the wrong side. Since my tank was repaired at a local metal shop and not an 'approved' aircraft repair place, the mechanic says that he wouldn't put anything in the logbook about the tank and figures it as an 'owner repair', and will deny any knowledge of it. He suggests to continue looking for an 'approved' left wing tank for my Ercoupe and replace it. I guess that's what I get for a 60 year old plane... My cousin Verlus was available to fly me to Jackson on Wednesday (this) morning at 7:30. He took me over there arriving about 8AM and he took off back to Fairmont. The mechanic wasn't around yet. I waited at the airport until the mechanic showed up around 8:45 and we got the plane pulled out of the maintenance hangar and fueled it up the rest of the way. It's now back in its hangar in Fairmont. So, $1k for the annual, etc, $125 for the tank repair, 2 trips to Minneapolis and a few trips over to Jackson, it's finally done. I was without the plane from June 30th until today and missed out on several fly-in breakfasts in the area (and Jay's pre-Oshkosh party?). Next year's annual will be due at the end of August so it 'should' be done early in September... THANKS to Montblack, Verlus, Roger and the others that have helped me with this issue! -Greg B. |
"Greg B" So, $1k for the annual, etc, $125 for the tank repair, 2 trips to Minneapolis and a few trips over to Jackson, it's finally done. I was without the plane from June 30th until today and missed out on several fly-in breakfasts in the area (and Jay's pre-Oshkosh party?). Next year's annual will be due at the end of August so it 'should' be done early in September... THANKS to Montblack, Verlus, Roger and the others that have helped me with this issue! What issue? g "I deny any knowledge of it." http://pg.photos.yahoo.com/ph/landof10klakes/album?.dir=/5a66re2 Select Slideshow (above the 4th picture) Select Slow (Normal is the default speed) July 15th. No titles or descriptions, just pics: 1. Tank was disassembled at the gas cap end. 2. Old (pre-war) method was to fold and solder the two pieces together. 3. End tank piece "fold" (which is about half of the flange) didn't want to refold neatly after the baffle was re-soldered back into place. Much tearing, like thin lead. "Bye, Greg. Good luck." Montblack |
this issue! Holy Crikey, Greg -- no wonder you've been AWOL. Your experience exactly matches mine, whenever I try to "save money" on a repair. It always, always, ALWAYS ends up taking a dozen extra trips, a few more headaches, and, in the end, I always kick myself for doing it. Must be something about being "children of Depression-era parents", or something, that forces us to do all this extra stuff to save a buck. We're like lemmings to the sea, if there's a deal to be had over the next cliff! ;-) So when you coming to Iowa City? I STILL haven't seen this Ercoupe of yours! -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
("Jay Honeck" wrote)
I STILL haven't seen this Ercoupe of yours! I've seen the inside of one of its gas tanks. Montblack |
"Jay Honeck" wrote in message
oups.com... So when you coming to Iowa City? I STILL haven't seen this Ercoupe of yours! Possibly this Sunday??? The choices of fly-ins this weekend are Iowa City or Owatonna, MN. Hmmm.... -Greg B. |
Gulp!!
Did Montblack tell you about running into Syd Cohen at OSH? Tons of Ercoupe info poured from this man. He's a local Wisconsinite and if you need a contact, just email me. I wouldn't be suprised if he knew of a place to pick up a gas tank. Jim "Greg B" wrote in message ... My annual inspection on the Ercoupe was due in June. What I usually do is take the plane to the inspector late in the month and then he usually signs/dates it the next month so I get close to 13 months between annuals. So, I took my plane from Fairmont (FRM) to Jackson (MJQ) on June 30th expecting to get it inspected the first part of July and have it back for the many fly-in breakfasts during July and August. So much for that plan. When I last fueled up before taking it over for the annual, I saw in the left wing tank that one of the baffle/ribs had fallen down inside the tank and just laying on the bottom. I mentioned this to the mechanic/inspector and he said it would need to be repaired or replaced before he'd sign off the annual inspection. He called me a couple days later and said my options were to get the tank repaired or find a replacement and he had found refurbished replacements for around $1,600 or he could send my tank in someplace to repair for around $500. Plan A: I called up Wentworth Aircraft in Minneapolis and they said they had an Ercoupe tank in stock for $495. I told them I'd stop by and pick it up the next day; saving the shipping costs and time(?). I drove from Fairmont to Minneapolis and got to Wentworth at lunchtime. The salesman I talked with about the tank was out for lunch and no one else knew much about it. I waited around for the salesman and got the tank and drove it back to Jackson. This was on a Friday and by the time I got to the Jackson airport, the mechanic wasn't there but I left the tank there. The mechanic called me on following Monday morning saying the tank I got at Wentworth had sloshing compound used on it and that he wouldn't put it on my plane. I guess I should have checked the tank closer when I got it from Wentworth... Plan B: During that week I had exchanged E-mails with Montblack about my Ercoupe tank issue and he mentioned Roger Dufresne in Forest Lake that repairs Ercoupe tanks. Great! I went over to Jackson and picked up the Wentworth tank and assisted the mechanic with taking the original tank off. I took both tanks up to Minneapolis to return the one to Wentworth and repair the original one. I talked with Roger about repairing the tank and he said he's repaired a few of them but wanted me to get some fuel tank sealant. I found the sealant listed in Aircraft Spruce but needed it quickly. I checked a few places here in Fairmont and also stopped at a fuel tank (storage tanks) place in Mankato on the way to Minneapolis and no one had the sealant. This was on a Friday and I was going to meet Roger on Saturday to work on the tank. After dropping the Wentworth tank off and getting a refund, I drove up to Anoka County airport and gave Montblack a call. He said he could come over to the airport to meet me and offered me a place to stay overnight. When Montblack arrived, he showed me around the airport and I mentioned about the sealant I was trying to find. We stopped at one of the hangars where he knew some guys working on a Howard and we talked with them and they had some sealant in stock that we could borrow and replace on Monday (called a place in Brooklyn Park that had the sealant but couldn't make it over there before it closed). I had recognized the Howard (and the pilots) as the one that flew into Fairmont a couple years ago. Nice guys! On Saturday, Montblack and I went up to Forest Lake to get the original tank repaired. Met with Roger in Forest Lake and he said he had worked on the aluminum tanks that were riveted but hadn't worked on the terneplate style tank that I had that was soldered. He got the endplate of the tank unsoldered and got the baffle/rib back in place but then ran into problems getting the endplate soldered back on. He suggested taking it to a metal shop and getting a new endplate fabricated that could be riveted in and use the tank sealant. Plan C: I took the tank back to Fairmont and stopped at the first metal shop that I knew and he said he wouldn't touch it. He suggested the local heating/plumbing shop so I took it over there. I know the owner of the plumbing shop (fellow local pilot) and asked him if he could fabricate a new endplate. He said he was busy with air-conditioning calls (Minnesota heat wave in July) and would get back to me when he got it done. I kept calling on him every few days to see how he was coming on repairing the tank. I had hoped he would have it completed before he left for a few days at Oshkosh, no luck. When he got back from Oshkosh, I talked with him and he had a new endplate cut but wasn't able to bend it around the curved part with the tools he had and suggested another metal shop. I took the tank, the original endplate, the new unbent endplate piece and some tank sealant to the 3rd shop. He called me a few days later and said it was ready. I picked it up and paid him $125 for the repair. He had used the original endplate and got it silver soldered back on and said he pressure tested it. I drove the tank over to Jackson and the mechanic looked at it and said it looked OK but needed to be cleaned out and handed me a hose. I filled the tank with water and the endplate started leaking! Not a good thing. I guess it was good that we checked it before mounting it on the plane. I took it back to the 3rd metal shop and told him it leaks. I stopped by there a few days later and he had the tank ready, again. I took the tank home, filled it with water -- no leaks, on the repaired endplate! Last Wednesday, I tried to call the mechanic in Jackson to say the tank was ready but he wasn't around. Found out he had flown to Wisconsin and was weathered in someplace on his way back. He finally called me back Monday and said I could bring the tank over on Tuesday morning and assist on putting it back on. Ok, I figured I'd drive the fuel tank over, help him put it back on, fly the plane back to Fairmont and then get a ride back to Jackson to get my car. We mounted the tank onto the wing and I suggested that we check for leaks before putting all the fairings, floorboard and panels back on. I filled up 2 gas cans with $40 worth of avgas and put that in the tank. The endplate didn't leak, but the quick drain did... Ok, drain the fuel back into the gas cans, replace the o-ring in the quick drain and try it again. This time NO LEAKS. I helped put the faring back on (a 2 person job) with me standing on my head inside holding the ny-lock nuts while he tightened the screws from the outside. I reinstalled the floorboards, attached the brake pedal (glad I don't have the rudder pedals!) and got the inside completed while he finished up the hardware on the outside. He had replaced the landing gear donuts and the fuel floats (the old cork floats wouldn't float anymore) a couple weeks ago and just needed the tank installed before signing off the inspection. Done. With the replacement of the donuts and floats while in for inspection, it ended up costing 1 AMU. It was getting late on Tuesday and I was beat from standing on my head in the cockpit most of the day. I had the choice of flying in the heat of the day back to Fairmont and be carless the rest of the day until I could get a ride back to Jackson to get my car or just driving back and get a ride back to Jackson on Wednesday. Some things I've found out about Ercoupe fuel tanks. There are different types depending on the S/N of the aircraft. Around serial number 813, they changed the landing gear configuration and the fuel tanks for under that number need a 'notch' in the tank for the gear. The ones after S/N 813 are straight across the back edge and are usually aluminum and riveted together. The older terneplate style ones (like mine with the 'notch') are stainless steel (or alloy?) with part of it riveted and part silver soldered. The tank that I had picked up at Wentworth was the 'new' style anyways and wouldn't have fit even if it didn't have the sloshing compound problem. I have been calling all over the country the past month getting information on tanks and trying to find a replacement that will fit my under 813 Ercoupe. I have found several places that have Ercoupe tanks, either for higher serial numbers or the wrong side. Since my tank was repaired at a local metal shop and not an 'approved' aircraft repair place, the mechanic says that he wouldn't put anything in the logbook about the tank and figures it as an 'owner repair', and will deny any knowledge of it. He suggests to continue looking for an 'approved' left wing tank for my Ercoupe and replace it. I guess that's what I get for a 60 year old plane... My cousin Verlus was available to fly me to Jackson on Wednesday (this) morning at 7:30. He took me over there arriving about 8AM and he took off back to Fairmont. The mechanic wasn't around yet. I waited at the airport until the mechanic showed up around 8:45 and we got the plane pulled out of the maintenance hangar and fueled it up the rest of the way. It's now back in its hangar in Fairmont. So, $1k for the annual, etc, $125 for the tank repair, 2 trips to Minneapolis and a few trips over to Jackson, it's finally done. I was without the plane from June 30th until today and missed out on several fly-in breakfasts in the area (and Jay's pre-Oshkosh party?). Next year's annual will be due at the end of August so it 'should' be done early in September... THANKS to Montblack, Verlus, Roger and the others that have helped me with this issue! -Greg B. |
Dude...are you on the Ercoupe Owners Club email lists? You really
need to be: http://ercoupers.com/lists.htm |
"Bob Fry" wrote in message
... Dude...are you on the Ercoupe Owners Club email lists? You really need to be: http://ercoupers.com/lists.htm I am now... Thanks Bob! |
Jay Honeck wrote:
THANKS to Montblack, Verlus, Roger and the others that have helped me with this issue! Holy Crikey, Greg -- no wonder you've been AWOL. "Holy Crikey"? That's a new one Jay :-) Glad to hear the plane is back together Greg. Sounds like (not) a lot of fun. Hmmm, maybe MontBlack has a new line of work as an airplane parts/information broker. If only he could slow down the web surfing and get on the MontJet project... -- Jack Allison PP-ASEL-Instrument Airplane "To become a Jedi knight, you must master a single force. To become a private pilot you must strive to master four of them" - Rod Machado (Remove the obvious from address to reply via e-mail) |
Owatonna, MN. Hmmm.... We'll be working our booth at the annual SERTOMA Fly-In Breakfast at our airport this Sunday. We'll look for you there! -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
| Thread Tools | |
| Display Modes | |
| Many "firsts" today - LONG | Jase Vanover | Piloting | 3 | March 12th 06 11:42 AM |
| Instruement checkride...for real this time (long) | Jack Allison | Piloting | 28 | February 28th 06 04:26 AM |
| TEST PILOTS ACCOUNT OF INFLITE BREAK UP (SR 71) (LONG) | caleb | Owning | 1 | January 30th 06 06:01 AM |
| SWRFI Pirep.. (long) | Dave S | Piloting | 19 | May 21st 04 04:02 PM |
| Helicopter gun at LONG range | Tony Williams | Naval Aviation | 3 | August 20th 03 03:14 AM |
