Class B VFR
Old August 31st 06, 05:32 PM posted to rec.aviation.piloting
Matt Whiting
Default Class B VFR
I'm hoping to make my long VFR cross-country for my commercial license
this afternoon and evening (to get both day and night into one flight).
I'm tentatively planning to fly into CAK which is class bravo
airspace. As I was planning the flight today, I realized that I haven't
flown VFR into class B in I can't remember when. I've flow IFR almost
exclusively since getting the rating 14 years ago.
I know that clearance is required to enter class B, but IFR this was
taken care of. I assume that the approach controllers routinely issue
this clearance when your destination is field in their area, but I
wanted to be sure. My plan is to request the clearance if I have
received it prior to entering class B, but I'm wondering what the SOP is
these days for VFR into class B.
Matt
Old August 31st 06, 05:47 PM posted to rec.aviation.piloting
Jim Burns[_1_]
Default Class B VFR
If you are on a VFR flight following, you'll be transferred just as IFR and
should be issued a clearance before entering OR you may be told not to enter
Class B airspace. If you do not use flight following, it's the same as
entering class C airspace... listen to ATIS, call up on the correct
frequency before entering and tell them what you want to do. Listen for the
clearance and your N number as positive identification. Shouldn't be a
problem.
"Matt Whiting" wrote in message
Matt
Old August 31st 06, 05:54 PM posted to rec.aviation.piloting
pgbnh
Default Class B VFR
Not sure I would take the chance of waiting for, or assuming a clearance
into the B. It is YOUR responsibility to get it, not theirs to give it to
you. At an appropriate distance from the Class B make the request, including
the altitude and route you intend to transit the B at.
"Jim Burns" wrote in message
and
enter
problem.
Matt
Old August 31st 06, 06:18 PM posted to rec.aviation.piloting
john smith
Default Class B VFR
Is KCAK CBAS?
Better check your charts and AFD.
You may want to restate your question after looking up the appropriate
information. :-))
Old August 31st 06, 06:27 PM posted to rec.aviation.piloting
Jose[_1_]
Default Class B VFR
My plan is to request the clearance if I have received it prior to entering class B, but I'm wondering what the SOP is these days for VFR into class B.
Request clearance into the Bravo airspace. Do not assume that clearance
into a point within Bravo airspace, or that would require transit of the
Bravo airspace, is an implicit clearance into it. It is not. You must
hear the magic words "Cleared into the Bravo".
Jose
The monkey turns the crank and thinks he's making the music.
Old August 31st 06, 06:33 PM posted to rec.aviation.piloting
Sylvain
Default Class B VFR
as someone pointed it out, you want to proactively ask for the
clearance ahead of time; get yourself the terminal chart for that
area, and look on the back of it, it describes the recommended/suggested
VFR transition routes.
I have flown through class B in VFR a few times (San Francisco,
Los Angeles, Las Vegas), and it never was a problem.
--Sylvain
Old August 31st 06, 07:13 PM posted to rec.aviation.piloting
Roy Smith
Default Class B VFR
No different than it's always been.
En-route, call up approach 10 miles from the CBAS boundary (not a hard
and fast rule, but it helps to give the guy some warning). Tell him
exactly what you want to do:
"New York Approach, Archer 25629, Islip, 4500, request Class Bravo
along the south shoreline then up the Hudson to White Plains". He'll
either give you a squawk and a clearance, or say unable. If you call
up too far out, you may be talking to somebody in the wrong sector and
he'll just give you a squawk and ask you to make your request with the
next controller.
It's easier if you've already got flight following, because the guy
will already have a strip on you, you'll have a squawk, etc.
If I'm taking off from White Plains (under the 3000 foot ring of the
NY CBAS), I'll ask clearance delivery to get me a class bravo before I
even taxi. Usually, I'll get something like, "Remain clear of the
class bravo at or below 1500, squawk XXXX, departure frequency 126.4".
As soon as I take off, they'll turn be over to departure (who is
already expecting me) and I'll get my class bravo clearence from him.
That's how it's supposed to work. Now, here's how it can go wrong.
This happened to me a couple of months ago.
I did exactly as described above, called up departure, and got "Radar
contact, cleared into the Class Bravo, fly heading 270, climb and
maintain 4500, contact New York Approach on 127.6". Translated into
English, that means, "Here's your ticket kid, now go bother the guy
who's running approaches into Newark". Not surprisingly, I couldn't
get a word in edgewise on 127.6. So, here we are, chugging along on a
270 heading (not the direction I wanted to go) and can't even find
enough space on the freq to check in with the new controller. This
went on for a while until finally we hear, "callsign, descend below
the floor of the class bravo, radar services terminated, frequency
change approved".
Well gee, if you didn't want to work us, why did you accept the
handoff? Anyway, these things happen. Just stay on your toes, listen
up on the freq, and always have another plan in your back pocket.
Most of the time, the NY controllers are very accomodating. They may
be working the most complicated airspace in the universe, but they're
also the best controllers in the universe, so it works out.
I routinely get clearances to fly up or down the Hudson or the East
River at anywhere from 1500 to 6500, just for sightseeing. I'm much
happier in the CBAS at 1500 than on the CTAF at 1000. Hint, loop
around Manhattan clockwise (down the East River, up the Hudson) to
give your pax a better view. Counter-clockwise if you want the good
view for yourself. Best one I got was coming through northbound,
descending out of 7500 or some such. I wasn't getting down fast
enough to get under the LaGuardia arrivals, so the controller had us
to a right descending 360. The Empire State Building makes a really
nice pylon for turns around a point!
Old August 31st 06, 07:15 PM posted to rec.aviation.piloting
Steven P. McNicoll[_1_]
Default Class B VFR
I'm tentatively planning to fly into CAK which is class bravo airspace.
As I was planning the flight today, I realized that I haven't flown VFR
into class B in I can't remember when. I've flow IFR almost exclusively
I know that clearance is required to enter class B, but IFR this was taken
care of. I assume that the approach controllers routinely issue this
clearance when your destination is field in their area, but I wanted to be
sure. My plan is to request the clearance if I have received it prior to
into class B.
CAK has Class C airspace.
Old August 31st 06, 07:24 PM posted to rec.aviation.piloting
Kingfish
Default Class B VFR
john smith wrote:
Is KCAK CBAS?
information. :-))
Got me curious. KCAK is a Class C airport that lies under Cleveland's
southern Mode C veil. Unless you're approaching from the north you
wouldn't be in the Class B. Of course, if you do find yourself nearing
the Bravo ya gotta be proactive as another poster said and request a
transition clearance at X altitude and advise of your intentions.
Old August 31st 06, 07:45 PM posted to rec.aviation.piloting
Matt Whiting
Default Class B VFR
Correction, that should have said CLE, not CAK. I may choose CAK if the
weather stays sufficiently south.
Matt
SPORTS CLASS/CLUB CLASS 5 ugly Soaring 0 July 2nd 06 11:14 PM
Carrying flight gear on the airlines Peter MacPherson Piloting 20 November 25th 04 12:29 AM
