spin balancing a tail rotor
Old September 8th 06, 05:01 AM posted to rec.aviation.rotorcraft
Stuart & Kathryn Fields
Default spin balancing a tail rotor
We recently received an article for our magazine where the author performed
a balance of his tail rotor on a bench using an electric motor and a dial
indicator instead of an electronic balancer. I was impressed with his
thinking outside the box. If there is any interest in this out there, I
will see if the author would be willing to discuss his technique here.
Stuart Fields
Experimental Helo magazine
P. O. Box 1585
Inyokern, CA 93527
(760) 377-4478 ph
(760) 408-9747 publication cell
Old September 8th 06, 03:43 PM posted to rec.aviation.rotorcraft
Don W
Sounds neat. I'd like to hear how he did it. It
seems that the dial indicator would tell you how
good the balance was, but would not be very good
at telling you which side was heavier.
Don W.
Old September 8th 06, 07:15 PM posted to rec.aviation.rotorcraft
Don: It turns out that this guy used the information in an article written
for our magazine by Larry Meidell , who according to Chadwick is a supremely
talented helicopter vibration analyst, and that technique does not require
phase angle information. Evidently the technique was originated, used and
written up by Russians who did not have access to an electronic balancer at
the time. I have used the same technique on some balancing that I have done
using instead of the dial indicator just the accelerometer without using any
of the phase angle information. It works. The technique involves a bit of
graphics and drawing circles. Our September 2006 issue of the Experimental
Helo magazine had this guys article and the original article by Meidell was
in the July 2005 issue, with a follow on article written by me on the
adaptation of the technique to a two rotor system which appeared in the Sept
2005 issue. If you have access to these issues of Experimental Helo, there
is a fairly complete story on the process.
Stuart Fields
P. O. Box 1585
Inyokern, CA 93527
(760) 377-4478
(760) 408-9747 general and layout cell
(760) 608-1299 technical and advertising cell
www.vkss.com
www.experimentalhelo.com
"Don W" wrote in message
om...
Don W.
performed
dial
Old October 23rd 06, 01:04 AM posted to rec.aviation.rotorcraft
Don: It turns out that the Russians were doing this, or something like it,
for some time
The method is basically make a run and record the peak dial indicator
reading. Add a weight to an arbitrary designated zero position. Make
another run and record that dial indicator reading. Now move that weight to
a position 120 degrees around from the zero position and make sure the
weight is installed at exactly the same distance from center that it was at
the zero position. Record the dial indicator reading and move the weight to
the 240 position, again at the same radial distance from the center and
record. Assign a graphical scale to the dial indicator readings and plot
first a circle representing the reading without a weight. Next plot a
second circle centered on the first circle at the zero degree position. Now
plot the next circle similarly at the 120 position on the first circle and
again the last circle centered on the 240 position. You should have an
intersection of all of the circles at one point. The distance from the
center of the first circle to this point represents that amount of weight
needed to correct the imbalance. The angle to this intersection represents
the angle measured from where you added the first weight to this
intersection point and designates the location to add the weight. In actual
practice you don't always get a point at the intersection but an small area.
The center of this area is used as the intersection point. I have used this
on the tail rotor of my helicopter successfully but used and accelerometer
instead of the dial indicator. The guys article in the magazine had color
plots of his graphical calculations.
Stuart Fields
P. O. Box 1585
Inyokern, CA 93527
(760) 377-4478 ph
om...
Sounds neat. I'd like to hear how he did it. It seems that the dial
indicator would tell you how good the balance was, but would not be very
good at telling you which side was heavier.
Don W.
performed a balance of his tail rotor on a bench using an electric motor
and a dial indicator instead of an electronic balancer. I was impressed
with his thinking outside the box. If there is any interest in this out
there, I will see if the author would be willing to discuss his technique
here.
Old October 23rd 06, 04:33 AM posted to rec.aviation.rotorcraft
Don W
Seems like you are describing a method for
balancing a 3-blade system since it requires
placing weights at 120, 240, and 360 degrees
successively but at the same radius.
There should be a similar method for a two-blade
system which involves placing the weights at
different radii and plotting the vibration using
the dial indicator.
Or am I missing something??
Don W.
for some time
Old October 23rd 06, 05:15 AM posted to rec.aviation.rotorcraft
Jim Carriere
Don W wrote:
Seems like you are describing a method for balancing a 3-blade system
since it requires placing weights at 120, 240, and 360 degrees
There should be a similar method for a two-blade system which involves
placing the weights at different radii and plotting the vibration using
the dial indicator.
You can probably add the weights at whatever angle is most convenient
(if the rotor hub has a balance wheel with three holes evenly spaced at
120 degrees, or four at 90 degrees...) and then plot the circles
accordingly. My understanding is the solution will give you how much
weight to add and where (in degrees from your reference) to add it, and
that you add the solution weight at the same radius you added the test
weight (probably a washer or washers).
I gather the number of blades is irrelevant to this method. Besides,
adding and subtracting weights to two opposing blades only affects
spanwise balance (not chordwise, which is usually much smaller anyway).
Old October 23rd 06, 06:24 PM posted to rec.aviation.rotorcraft
Don W
using the dial indicator.
I was missing something. I didn't realize that
there was a balance wheel on the hub. It makes
sense now.
Don W.
Old October 23rd 06, 06:33 PM posted to rec.aviation.rotorcraft
You are pretty much correct. I did a conversion from three blade to two
blade in an article in the magazine. The catch is assuming the zero
position corresponds to a spot down the chord line of the blade, you have to
scale the weight up when you move it to the 90 and 270 degree spots to have
the product of the distance from the center times the weight to be the same
as that used at the zero position. Also the correction weight displayed in
the graphic solution assumes the installation will occur at the same
distance from center used in the zero position. If this is not true, then
it must be scaled to obtain the correct weight times distance product.
There is a minor problem using the dial indicator as the sensor for the main
rotor in that most main rotor balancing is done at flight speed and with the
helicopter in hover. It makes the reading of the dial indicator tough.
Also finding a stable mount for the dial indicator is more tricky than using
a velocimeter or accelerometer.
The graphical method is very handy when the phase angle measurements are
flaky, which does occur if you are anywhere near a critical speed of the
rotating system. I've experienced problems with balancing my tail rotor
using the phase angle measurements when the helicopter is setting on a
concrete or asphalt pad. On grass it is OK . The graphical technique
ignores the concrete issue.
Stuart Fields
P. O. Box 1585
Inyokern, CA 93527
(760) 377-4478
www.vkss.com
"Jim Carriere" wrote in message
the dial indicator.
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 04:55 AM
Most reliable homebuilt helicopter? tom pettit Home Built 35 September 29th 05 03:24 PM
Mini-500 Accident Analysis Dennis Fetters Rotorcraft 16 September 3rd 05 12:35 PM
Parachute fails to save SR-22 Capt.Doug Piloting 72 February 10th 05 06:14 AM
