Landings question
Old September 9th 06, 10:52 AM posted to rec.aviation.soaring
Cats
Default Landings question
I am one of those people with ongoing intermittent landing problems. I
have good patches - managed to get solo recently - and then bad
patches. The bad patches probably co-incide with forgetting to look up
as I start the round-out, so there is no hold-off and a rather heavy
landing, sometimes with a bounce.
I've got my own ideas on how to address this, was curious if anyone
else here has had the same problem and if so, how did you deal with it?
Unfortunately I reckon I developed the bad habit fairly early in my
flying, as it was well-established by the time someone pointed out what
was going on. Since I seem to be reasonably good at doing what I'm
told to do, via a route from ears to hands & feet that misses my brain,
I suspect I've flattered to deceive in the front seat.
Old September 9th 06, 02:30 PM posted to rec.aviation.soaring
Doug Haluza
Sounds like you have identified the most likely cause. I tell students
to watch the spot on approach, then when it is in "point blank range"
there is no need to look at it any more, and it's time to look at the
other end of the runway.
Tom Knauff has students stand near the runway and bend at the knees to
simulate the last part of the landing hold-off. You look down the
runway and note the perspective changes that are the cues you need to
maintain a slow descent. For a comparison you can also look at the
ground near your feet to see how ineffective this is.
Old September 9th 06, 03:07 PM posted to rec.aviation.soaring
Papa3
I have students sit in the glider while two other folks stand outside:
one levels the wings, the other one stands at the tail. We then lift
the tail to the pitch attitude that approximates approach speed to get
a good feel for that sight picture. I ask the student to carefully
pick some reference points and try to ingrain those in his/her mind.
We then rotate to landing attitude and to the same. I really want the
person to get the idea that they rotat to a certain attitude and then
hold there while speed bleeds off. Obviously, this isn't perfect,
since the rotation really needs to happen a little bit higher up
(grin), but it does give the sense for the amount of pitch change
required.
Depending on the aircraft, the rotation can be pretty significant (e.g.
a 2-33) or pretty subtle (e.g. a G103).
I definitely agree that getting yourself to focus on a point in the
distance (e.g. tree tops at the far end of the runway) makes this whole
process easier. Whatever you do, spend some time on the ground in the
airplane fooling around with this.
Erik Mann
LS8-18 P3
p.s. A good friend of mine did the same thing for me when I was trying
to learn to fly taildraggers in a J3 Cub. It was really helpful to
get a sense for the min and max pitch attitudes required.
Old September 9th 06, 05:24 PM posted to rec.aviation.soaring
bumper
"Cats" wrote in message
ps.com...
First, make sure your altimeter is accurately set before launch. Then, when
on short final, carefully watch the altimeter instead of the runway. When at
5 feet AGL, push the stick forward all the way - - hard. While this method
will not usually result in the smoothest of landings, whatever landings you
do manage to accomplish, before being kicked out of your club or banished
from the airfield, will all be pretty much consistent.
all the best,
bumper
Old September 9th 06, 06:06 PM posted to rec.aviation.soaring
kirk.stant
So, bumper, it started to rain on your way to the gliderport this
morning?
Then again, I must admit I have seen some landings that seem to have
used the procedure you describe - fun to watch, especially it it's a
G-103 being abused.
Something about practicing no-spoiler landings...
Cheers,
Kirk
66
Old September 9th 06, 08:23 PM posted to rec.aviation.soaring
Doug Haluza
Actually, this is not too far from what I was "taught" except that I
was told to watch the airspeed and fly the 2-33 right into the runway
and up on the skid. It wasn't until I was preparing for my commercial
checkride that I had an instructor actually teach me how to land.
all the best,
bumper
Old September 9th 06, 11:07 PM posted to rec.aviation.soaring
Private
ps.com...
I am not a CFI or CFIG so claim no authority, but/and can only comment on
what worked for me.
It is said by many that the route to good landings is practice, practice,
practice. The key is not to keep practicing your mistakes. Learning to
land in gliders is difficult because it is hard (and expensive) to do enough
of them. Tows are expensive and we seldom make more than a small number of
landings in a training day. IMHE the best way to learn to land is with a
GOOD CFI, in a light tailwheel aircraft and at a small quiet airport. This
will allow you to make many landings in an hour and is much more cost and
time effective than purchasing tows. Gliders require ground crews for
assistance and it is hard to get more than 4 landings /hr. An aircraft
needs no assistance and can easily make 12 or more landings in an hour, and
the cost per landing will be a small fraction of the cost of gliders + tows.
A winch will change the economics but I suspect that the powered aircraft
will still be much cheaper. My personal favorite trainer is the Citabria
but the quality and experience of the CFI is much more important than the
choice of aircraft.
All students do not have identical learning styles. Some wish only to
memorize the mechanics and procedures, while others require a deeper
understanding of why the procedures function. The penny dropped for me
(after hundreds of just fair landings) after I learned the math and I could
understand WHY the flair required that the AOA be increased at a smooth
accelerating RATE as the aircraft slows in the holdoff (hint, think about
the Vsquared part of the lift formula), in order to allow the increasing
drag to bleed off speed and energy . There is a lot going on in the
roundout and again as an aircraft gets close to quitting to fly and the
control feedback (pressures) and visual perception becomes quite subtle.
IMHO, It is our job as pilots to place the aircraft at the right location
and speed (energy) and altitude and with the right attitude so that the
aircraft can decide when it wants to stop flying and land.
Happy landings to all,
Private
This was my experience also. I think the instructors were trying to reduce
the rollout so they did not need to push back as far. We did spend a lot of
time replacing worn skids.
"Doug Haluza" wrote in message
when
at
method
you
all the best,
bumper
Old September 10th 06, 12:33 AM posted to rec.aviation.soaring
Roger Worden
A couple of possibilities come to mind. Do you think one of these applies?
1. Rounding out too late, and therefore hitting the ground before achieving
a level attitude
2. Rounding out OK but raising the nose too much, then losing speed and
stalling, resulting in a short drop to the ground?
I've noticed a couple of times recently that I got distracted after rounding
out OK (perhaps by needing to correct my direction or to level my wings) and
let my speed get too low. That causes a stall at just a foot or half-foot
above the ground, leading to a bump onto the ground.
ps.com...
Old September 10th 06, 12:50 AM posted to rec.aviation.soaring
Mike Schumann
My worst landing ever was caused by being too fast when I flaired and then
failing to use the spoilers to help drain energy. I ended up with some
pretty serious PIO and a number of hard bounces.
Mike Schumann
"Roger Worden" wrote in message
. net...
achieving
a level attitude
rounding
and
ps.com...
A question on Airbus landings [email protected] Piloting 17 July 18th 06 10:05 PM
Precision Landings and practice [email protected] Piloting 34 December 17th 04 03:08 PM
Night landings vs. day landings Gerald Sylvester Piloting 15 February 12th 04 07:38 AM
Tailwheel endorsement John Harper Piloting 58 December 12th 03 02:48 PM
