Borgelt B40 averager
Old September 17th 06, 01:14 AM posted to rec.aviation.soaring
Michael Schlotter
Default Borgelt B40 averager
Does anybody know which sort of signal goes from the
Borgelt B40 vario to the external averager? Is it just
a voltage or something more complicated? The reason
I want to know it is that I'd like to make up my own
display instead of buying the original one which is
rather bulky. The only alternative would be to buy
the small display for the B400, but are they compatible?
Any comments welcome.
Old September 17th 06, 01:59 AM posted to rec.aviation.soaring
Marc Ramsey
The logic person to contact is Mike Borgelt, you can get his email
address from his web site. I've always found him to be quite helpful
with questions like this. The signal from the B40 is analog, I believe
it swings +/- 1V (+/- 10 kts or 5 m/s) from a 2.5V reference. I believe
the same signal is used for the repeater, so the averaging is likely
being done by a separate circuit in the external unit...
Marc
Old September 17th 06, 02:57 AM posted to rec.aviation.soaring
BTIZ
our B40 has a built in averager, only displayed when the button is
depressed..
would not that voltage be reported to the external averager for display?
Granted I think the external averager is digital display
BT
"Marc Ramsey" wrote in message
t...
The logic person to contact is Mike Borgelt, you can get his email address
from his web site. I've always found him to be quite helpful with
questions like this. The signal from the B40 is analog, I believe it
swings +/- 1V (+/- 10 kts or 5 m/s) from a 2.5V reference. I believe the
same signal is used for the repeater, so the averaging is likely being
Marc
Old September 17th 06, 12:03 PM posted to rec.aviation.soaring
Mal
http://www.borgeltinstruments.com/
FS: Variometer Tasman V1000 audio with averager. United States [email protected] Soaring 0 January 26th 06 10:36 PM
Wanted - Borgelt B50, Ilec SB-8 or similar [email protected] Soaring 1 August 19th 05 04:20 PM
Simple audio vario + averager? Chris Reed Soaring 2 June 11th 04 01:00 PM
Borgelt website update Mike Borgelt Soaring 6 December 1st 03 08:47 PM
Borgelt B50 and B57 Mal Soaring 1 October 26th 03 02:42 PM
