Engine stoppage during idle
Old September 19th 06, 06:11 AM posted to rec.aviation.owning
tony roberts[_1_]
Default Engine stoppage during idle
I would start by checking idle at start and at operating temp.
To me, revs should not have been 500
Tony
C-GICE
Peter wrote:
IO-540-C4, Socata TB20
Just got this today. Landed, taxied off the runway, and before doing
the post-landing procedure (ie, with the mixture on full rich and the
fuel pump still running) noticed the revs to be very low, c. 500 and
then unsuprisingly the engine stopped.
Initially I suspected the idle setting had got moved. Did a start (hot
start, the usual lots of cranking) and all was fine. Idle is perfect
at 700rpm, just the way it was set up by a very good Socata engineer a
couple of years ago. Mag checks fine, EDM700 fine.
Nothing special about the conditions. OAT +19C, DP +15C, 1hr flight at
2000ft.
Enquiries suggest this sort of thing happens every once in a while.
I just haven't had it in 500+ landings in this aircraft, so it is
suprising.
Any views would be much appreciated.
I am considering having the fuel system inspected for
debris/blockages.
Tony Roberts
PP-ASEL
VFR OTT
Night
Cessna 172H C-GICE
Centurion FAQ with kibbitzing Bret Ludwig Home Built 0 November 12th 05 10:39 PM
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 06:42 PM
Autorotation ? R22 for the Experts Eric D Rotorcraft 22 March 5th 04 06:11 AM
What if the germans... Charles Gray Military Aviation 119 January 26th 04 11:20 PM
Corky's engine choice Corky Scott Home Built 39 August 8th 03 04:29 AM
