Engine stoppage during idle
Old September 19th 06, 04:48 PM posted to rec.aviation.owning
Newps
Default Engine stoppage during idle
Why was the pump on and why were you at full rich?
Peter wrote:
IO-540-C4, Socata TB20
Just got this today. Landed, taxied off the runway, and before doing
the post-landing procedure (ie, with the mixture on full rich and the
fuel pump still running) noticed the revs to be very low, c. 500 and
then unsuprisingly the engine stopped.
Initially I suspected the idle setting had got moved. Did a start (hot
start, the usual lots of cranking) and all was fine. Idle is perfect
at 700rpm, just the way it was set up by a very good Socata engineer a
couple of years ago. Mag checks fine, EDM700 fine.
Nothing special about the conditions. OAT +19C, DP +15C, 1hr flight at
2000ft.
Enquiries suggest this sort of thing happens every once in a while.
I just haven't had it in 500+ landings in this aircraft, so it is
suprising.
Any views would be much appreciated.
I am considering having the fuel system inspected for
debris/blockages.
Old September 19th 06, 06:01 PM posted to rec.aviation.owning
Newps
You're running way too rich.
Peter wrote:
Because that is how it is when one lands.
I have done some test runs today and found that the problem can be
repeated if one quite decisively pushes the throttle shut - that drops
the RPM from 700 to about 500. It happens only when the engine is
warm; say CHT of 330F or higher. The mixture doesn't really affect it.
So it seems OK, but I might inspect the throttle linkage anyway.
Old September 19th 06, 07:28 PM posted to rec.aviation.owning
Denny
Well Peter, I don't know who is telling you to configure the engine
that way for landing but you may want to poll the big bore drivers on
here... I can tell you from experience with injected 360-520-540-720,
that many a hot engine will quit if used like that...
Personally, I leave the engine partially leaned in the landing
pattern...
denny
Old September 19th 06, 10:23 PM posted to rec.aviation.owning
Dave Butler[_1_]
pattern...
I can see it both ways.
In the UK, the SOP is to go max-rpm and full-rich on short final, in
anticipation of a go-around.
That's SOP in the US, too. I've never heard of what Denny and Newps are
suggesting, but then I don't fly a big-bore, and don't keep up with
their SOPs.
Old September 20th 06, 02:04 AM posted to rec.aviation.owning
Dan[_1_]
Yes, sometimes this is necessary. Especially at high density
altitude.
--Dan
pattern...
denny
Old September 20th 06, 05:14 AM posted to rec.aviation.owning
Newps
There's two reasons not to go to full rich for landing. For me the most
important is density altitude. I live at 3650 msl and see lots of
flatlanders land full rich on a 90 degree day and have the engine quit
on rollout. Running full rich in these situations is just ****ing power
away when you need it. The second reason is fouling the plugs.
pattern...
their SOPs.
Old September 20th 06, 07:04 PM posted to rec.aviation.owning
Matt Barrow
"Dave Butler" wrote in message
suggesting, but then I don't fly a big-bore, and don't keep up with their
SOPs.
In a piston popper, of any size, the engine responds quickly enough that
full rich/RPM's is more damaging, unless you like lead fouling in your
engine.
Matt
Matthew W. Barrow
Site-Fill Homes, LLC.
Montrose, CO (MTJ)
Old September 20th 06, 07:20 PM posted to rec.aviation.owning
Matt Barrow
"Newps" wrote in message
flatlanders land full rich on a 90 degree day and have the engine quit on
rollout. Running full rich in these situations is just ****ing power away
Quite!
http://www.avweb.com/news/pelican/182085-1.html (last couple, three
paragraphs)
Matt
Matthew W. Barrow
Montrose, CO (MTJ)
Old September 21st 06, 01:42 AM posted to rec.aviation.owning
This sure suggests that the problem lies with the throttle idle stop,
possibly a mechanical misalignment between the stop adjustment ant the cam
on the throttle control that is supposed to hit it. The misalignment may be
temperature related, i.e. the cam/stop orientation changes just a bit
between cold and hot conditions.
At any rate, if the engine otherwise runs fine this does not seem like a
serious problem.
-Elliott Drucker
Old September 22nd 06, 03:49 AM posted to rec.aviation.owning
Roger (K8RI)
On Wed, 20 Sep 2006 10:20:17 -0700, "Matt Barrow"
Quite!
paragraphs)
I'm learning to hate sites like this. I'm logged in via another route,
but it's not smart enough to know that when I follow this link.
www.rogerhalstead.com
Engine stoppage during idle Peter R. Owning 2 September 19th 06 04:57 PM
Engine stoppage during idle Denny Owning 0 September 19th 06 02:28 PM
Autorotation ? R22 for the Experts Eric D Rotorcraft 22 March 5th 04 07:11 AM
What if the germans... Charles Gray Military Aviation 119 January 27th 04 12:20 AM
Corky's engine choice Corky Scott Home Built 39 August 8th 03 05:29 AM
