Engine stoppage during idle
Old September 19th 06, 11:45 PM posted to rec.aviation.owning
[email protected][_1_]
Default Engine stoppage during idle
On Tue, 19 Sep 2006 05:36:55 +0100, Peter
IO-540-C4, Socata TB20
Just got this today. Landed, taxied off the runway, and before doing
the post-landing procedure (ie, with the mixture on full rich and the
fuel pump still running) noticed the revs to be very low, c. 500 and
then unsuprisingly the engine stopped.
Initially I suspected the idle setting had got moved. Did a start (hot
start, the usual lots of cranking) and all was fine. Idle is perfect
at 700rpm, just the way it was set up by a very good Socata engineer a
couple of years ago. Mag checks fine, EDM700 fine.
snip
RPM rise when pulling the mixture to ICO? Cold vs. hot?
If it's hard to determine @ 700, try it closer to 1000.
You may not be able to see it on the tach, but you should be able to
hear a slight RPM increase as the mixture is pulled. No rise, idle
mixture is too lean-more than a little (25-50 RPM), idle mixture too
rich.
Ensure that the crank on the servo is positively contacting the idle
rpm stop before the throttle control reaches the end of its travel...
TC
Old September 20th 06, 12:29 AM posted to rec.aviation.owning
Roger (K8RI)
snip
The Deb idle is 500, the mechanic wanted to see a slight rise when
slowly pulling the mix to cut off.
rich.
TC
www.rogerhalstead.com
Engine stoppage during idle Peter R. Owning 2 September 19th 06 04:57 PM
Engine stoppage during idle Denny Owning 0 September 19th 06 02:28 PM
Autorotation ? R22 for the Experts Eric D Rotorcraft 22 March 5th 04 07:11 AM
What if the germans... Charles Gray Military Aviation 119 January 27th 04 12:20 AM
Corky's engine choice Corky Scott Home Built 39 August 8th 03 05:29 AM
