Mxsmanic wrote
Why does it seem that wing tanks are filled in commercial airliners in preference to center tanks? What is the advantage to filling the wing tanks while keeping the center tank empty or partially filled? Wouldn't heavy wing tanks increase the inertia of the aircraft around the roll axis? In order to reduce the bending moment on the wing spar at the juncture with the fuselage. Longer airframe life. Bob Moore |
Bob Moore writes:
In order to reduce the bending moment on the wing spar at the juncture with the fuselage. Longer airframe life. But wouldn't putting weight inside the wings cause them to flex _more_, since the weight is now outside the wing root instead of within it? That's the part I don't understand. I guess that if the weight is in the fuselage, and the wings have to move the fuselage, there might be more stress on the wing roots; is that what you mean? In that case, I can see where putting the weight in the wings might reduce the stress at the point where they join the fuselage; although it still seems that it would put the wings under more stress when landing, and it would make the aircraft slower to respond to roll commands (which I presume isn't desirable). -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic schrieb:
fuselage; although it still seems that it would put the wings under more stress when landing, You don't typically land with full tanks. and it would make the aircraft slower to respond to roll commands (which I presume isn't desirable). I thought you didn't like aerobatic style roll maneuvres? Stefan |
Stefan writes:
I thought you didn't like aerobatic style roll maneuvres? Every turn involves some degree of roll movement. I don't mind it as long as the net acceleration vector continues to point down through my seat and the G load doesn't climb significantly. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote:
Bob Moore writes: In order to reduce the bending moment on the wing spar at the juncture with the fuselage. Longer airframe life. But wouldn't putting weight inside the wings cause them to flex _more_, since the weight is now outside the wing root instead of within it? That's the part I don't understand. I guess that if the weight is in the fuselage, and the wings have to move the fuselage, there might be more stress on the wing roots; is that what you mean? In that case, I can see where putting the weight in the wings might reduce the stress at the point where they join the fuselage; although it still seems that it would put the wings under more stress when landing, and it would make the aircraft slower to respond to roll commands (which I presume isn't desirable). One reason weight and balance. Another if you put a non compressible (realtively) fluid in a confined space it gets stiffer. Think full soda can vs empty. Try to crush a full one. Michelle P |
![]() "Michelle P" wrote in message ink.net... Mxsmanic wrote: Bob Moore writes: In order to reduce the bending moment on the wing spar at the juncture with the fuselage. Longer airframe life. But wouldn't putting weight inside the wings cause them to flex _more_, since the weight is now outside the wing root instead of within it? That's the part I don't understand. I guess that if the weight is in the fuselage, and the wings have to move the fuselage, there might be more stress on the wing roots; is that what you mean? In that case, I can see where putting the weight in the wings might reduce the stress at the point where they join the fuselage; although it still seems that it would put the wings under more stress when landing, and it would make the aircraft slower to respond to roll commands (which I presume isn't desirable). One reason weight and balance. Another if you put a non compressible (realtively) fluid in a confined space it gets stiffer. Think full soda can vs empty. Try to crush a full one. Michelle P Be sure to shake it vigorously first... Jay B |
Darrell R. Schmidt
B-58 Hustler Web Site URL (below) http://members.cox.net/dschmidt1/ "Jay Beckman" wrote in message news:%5eQg.39$La2.35@fed1read08... "Michelle P" wrote in message ink.net... Mxsmanic wrote: Bob Moore writes: In order to reduce the bending moment on the wing spar at the juncture with the fuselage. Longer airframe life. But wouldn't putting weight inside the wings cause them to flex _more_, since the weight is now outside the wing root instead of within it? That's the part I don't understand. Think of it this way, Bob. In level flight the wings basically support the aircraft total weight thereby tending to bend the wings upward at the wing root. Fuel in the wings make them heavier which tends to bend the wings downward from the wing root. If you put all the fuel weight in the fuselage it adds to the first situation only, tending to bend the wings upward. Fuel you place in the wings adds to the weight but also adds to the 2nd situation which fights the upward bending movement because of the weight of fuel in the wings themselves. (Some fancy aircraft like the SR-71 produce considerable lift from the fuselage which changes the situation somewhat) In many commercial jets the fuel is first burned from the center tank (within the fuselage) and then the wing tank fuel is burned. Sometimes, due to Center of Gravity (CG) situations it becomes necessary to retain some center tank fuel for CG purposes. That fuel is considered unuseable and it the only time that all the center tank fuel is not burned first. In the MD-80, fuel in the wings that is in contact with the upper wing surface contributes to ice forming on top of the wings. Because of that many users burn the wing tanks down a little before burning the center tank fuel. You were correct in your statement below that the stress at the wing roots is what is the most important consideration. You are also correct to state that fuel in the wings reduces roll authority, but you can just use more aileron/spoiler input and it is normally not a controlling element. I guess that if the weight is in the fuselage, and the wings have to move the fuselage, there might be more stress on the wing roots; is that what you mean? In that case, I can see where putting the weight in the wings might reduce the stress at the point where they join the fuselage; although it still seems that it would put the wings under more stress when landing, and it would make the aircraft slower to respond to roll commands (which I presume isn't desirable). One reason weight and balance. Another if you put a non compressible (realtively) fluid in a confined space it gets stiffer. Think full soda can vs empty. Try to crush a full one. Michelle P Be sure to shake it vigorously first... Jay B |
Darrell S wrote
Think of it this way, Bob. Darrell, I think that you have your attributes mixed-up. Bob Moore |
On Wed, 20 Sep 2006 13:52:21 +0200, Mxsmanic
wrote: Bob Moore writes: In order to reduce the bending moment on the wing spar at the juncture with the fuselage. Longer airframe life. But wouldn't putting weight inside the wings cause them to flex _more_, since the weight is now outside the wing root instead of within it? That's the part I don't understand. Remember the wings are supporting the airplane, not the other way around. Putting fuel out there makes enough difference in my plane that they increased the gross weight allowance to include all the fuel in the tip tanks, but that increase applies only if the extra weight is fuel in those tip tanks. I guess that if the weight is in the fuselage, and the wings have to move the fuselage, there might be more stress on the wing roots; is that what you mean? In that case, I can see where putting the weight in the wings might reduce the stress at the point where they join the fuselage; although it still seems that it would put the wings under more stress when landing, and it would make the aircraft slower to That is why most commercial aircraft have a maximum take off weight that is more than the allowable landing weight. respond to roll commands (which I presume isn't desirable). Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
Exposed Electrical Wires in Boeing 737 Fuel Tanks! | Larry Dighera | Piloting | 0 | July 17th 06 06:13 PM |
F-104 in Viet Nam Question | Don Harstad | Military Aviation | 2 | August 28th 04 08:40 AM |
Run-in with Chicago Center | Jay Honeck | Piloting | 93 | August 24th 04 04:53 PM |
Bush's Attempt to Usurp the Constitution | WalterM140 | Military Aviation | 20 | July 2nd 04 04:09 PM |
Long-range Spitfires and daylight Bomber Command raids (was: #1 Jet of World War II) | The Revolution Will Not Be Televised | Military Aviation | 20 | August 27th 03 09:14 AM |
