How can I get back into flying
Old September 22nd 06, 12:00 AM posted to rec.aviation.piloting
JPCOYLE
Default How can I get back into flying
Just curious. I had a Private Pilots license in the early 1970s. I havent
flown since then. Do I have to start over or is there a process to renew
with less time. I know that I will need a lot of retraining.
-Joe
Old September 22nd 06, 12:08 AM posted to rec.aviation.piloting
Newps
Find an instructor. You need a BFR at a minimum.
-Joe
Old September 22nd 06, 12:42 AM posted to rec.aviation.piloting
Jim Macklin
Best link http://www.aopa.org/learntofly/getback.html for a
series of step by step articles with guidelines by date you
last flew.
"JPCOYLE" u26966@uwe wrote in message
news:66a439b661d24@uwe...
1970s. I havent
process to renew
retraining.
| Thanks,
| -Joe
Old September 22nd 06, 01:15 AM posted to rec.aviation.piloting
Matt Whiting
-Joe
Do you still have your license or did you surrender it to the FAA when
you stopped flying? If you kept it, you need a BFR (probably a very
extensive one!) and you should be good to go. Obviously, you also need
a current medical.
Matt
Old September 22nd 06, 01:48 AM posted to rec.aviation.piloting
Mortimer Schnerd, RN[_2_]
I went through the same thing last year after a 15 year hiatus. Here's the
order I suggest:
1) Get a current third class medical. If you can't get one of these, there's
no point in looking any further or spending another dime.
2) Call around to the local FBOs and find an instructor / rental aircraft
situation you're comfortable with. I'd suggest you try to find the same kind of
aircraft you're most accustomed to if it's common enough. In my case, it was
the C-172, so that was no problem.
3) Drag out your old textbooks and look them over. Ignore the FAR section.
4) Buy a current copy of the AIM/FAR from Sporty's or whomever and set it by
the throne in the bathroom. Every time you go in there for a spell, read a
section of regulations or anything else that you know you're weak on. Spend
some time on this before you actually go to fly.
5) When you go for your first flight, tell the man you want a BFR but you
haven't flown in 30 years. You'll go out and do some airwork mixed with a
couple of hours of ground school. Do not expect to leave that day with a
current BFR... it's going to take a few sessions to get you back up to speed.
6) At whatever point the instructor is convinced you can go out flying without
having to alert Civil Defense, he/she'll sign your BFR and you're good to go...
VFR at least. How many sessions it takes is up to you. Performance is
everything. I got mine in two sessions.
As an aside, I picked up something from watching a Blue Angels documentary that
helped me when I was going to get reacquainted with the Arrow after so many
years away: before their flights they sit and imagine the flight... in your
case, every aspect of preflight, engine start, etc. I daydreamed my flight all
the way on the drive to the airport and when I actually climbed in, it was like
I had never left. I had to be reminded where the fuel drains were but very
little else.
Good luck and welcome back.
mschnerdatcarolina.rr.com
Old September 22nd 06, 02:36 AM posted to rec.aviation.piloting
Steve Foley[_2_]
"JPCOYLE" u26966@uwe wrote in message news:66a439b661d24@uwe...
-Joe
The only area I differ with everyone else is in getting a medical. If you
fail the exam, you cannot fly. If you do not try to get a medical, you can
still fly as a sport pilot.
Hopefully, this won't be an issue.
1343 NM to the NASM Udvar-Hazy Center and back... Jay Honeck Piloting 25 June 18th 05 06:07 PM
Routine Aviation Career Guy Alcala Military Aviation 0 September 26th 04 01:33 AM
Interesting Resume (V Long) Bob Chilcoat Piloting 24 September 13th 04 07:44 AM
McCall, Idaho: Mountain and Canyon Flying Seminars [email protected] Piloting 6 March 21st 04 08:45 AM
Across Nevada and Part Way Back (long) Marry Daniel or David Grah Soaring 18 July 30th 03 09:52 PM
