Why Isn't Vx The Best Rate Of Climb?
Old September 26th 06, 04:47 AM posted to rec.aviation.piloting,rec.aviation.student
RandyL
Default Why Isn't Vx The Best Rate Of Climb?
Here is something that I have always wondered about, but have yet to
hear a good explanation for. Vx is the best angle of climb speed for an
aircraft. Vy is the best rate of climb for an aircraft. I can't seem to
visualize why Vx is not the best rate of climb. To my feeble way of
thinking, Vx - the best climb angle - gets you to the highest altitude in
the shortest period of time, no? Why is that not the best rate of climb? I
hope someone can enlighten me on this. I know that there must be a good
explanation, but as I said, I just can't visualize it. Thanks...
Randy L.
Remember: Any landing that you can
walk away from, is a landing that you
can be fined, sued, or prosecuted for.
Old September 26th 06, 04:58 AM posted to rec.aviation.piloting,rec.aviation.student
peter
No, Vx will get you to a given altitude while covering the shortest
distance, but not generally in the shortest time. When climbing at a
steeper angle the plane will be going slower so even though Vx will get
you there in a shorter distance you'll get there a little quicker by
choosing a slightly shallower angle that lets you go faster, i.e. Vy.
It's similar to choosing whether to climb a mountain by either going
straight up the side in which case you may need ropes and make very
slow progress, or by hiking up the less steep switchback trail in which
case you'll have to go farther but will be able to go faster.
Old September 26th 06, 06:40 PM posted to rec.aviation.piloting,rec.aviation.student
RandyL
Thanks Peter - and everybody who replied to this. It took a mighty effort,
but I think I may have finally wrapped my brain around this concept. Take
care...
Randy L.
"When making an emergency off-field
landing at night, turn on the landing lights
just prior to touchdown.
If you don't like what you see, then turn
off the landing lights."
"peter" wrote in message
Old September 27th 06, 06:56 PM posted to rec.aviation.piloting,rec.aviation.student
Chris G.
Don't feel bad. It took me a while to grasp this concept effectively as
a student, too.
Chris
care...
Randy L.
Old September 26th 06, 05:14 AM posted to rec.aviation.piloting,rec.aviation.student
John Gaquin
"RandyL" wrote in message
Vy is time, and Vx is distance.
The key, Randy, is to look at what the definition says and consider the
words carefully. Best rate of climb considers feet of climb per unit of
time past, without considering distance travelled at all. Best angle of
climb considers feet of climb per unit of distance travelled, without
considering time at all.
.....To my feeble way of thinking, Vx - the best climb angle -
NO. There's part of your difficulty, possibly. Stick with the proper
terminology. Don't switch words around, because they mean something. "Best
angle of climb" is not necessarily the same thing as "best climb angle".
Old September 26th 06, 07:21 AM posted to rec.aviation.piloting,rec.aviation.student
Peter Duniho
I think the other two posts cover the basic definition adequately. I'll
offer a mental view that sometimes helps me understand the relationship, and
which might clarify the difference a little bit mo
Vy is about the best *rate* of climb. That is, the most vertical distance
over a period of time. Vx is about the best *angle* of climb. That is, the
most vertical distance of a horizontal distance.
That much has been explained. It may also be helpful to know that Vy occurs
when you have the most excess power, while Vx occurs when you have the most
excess thrust. Power, being a rate-based measure (that is, work (that is,
force times distance) over a period of time), winds up contributing to the
best climb performance over a period of time. On the other hand, thrust,
being a measurement of the specific force acting on the airplane (and which
is independent of time), winds up contributing to the best climb performance
when time is ignored.
I admit that the above may only be helpful if you already think in terms of
physics. But perhaps it provides some additional insight into why there
even are two different V speeds and how they relate to the definitions of
them.
Pete
Old September 26th 06, 08:41 AM posted to rec.aviation.piloting,rec.aviation.student
Roger (K8RI)
On Mon, 25 Sep 2006 23:21:44 -0700, "Peter Duniho"
You might try the reverse order too. Look at best glide speed. In
calm air the best glide speed gives you the most distance per time
unit, but traveling either faster or slower will cause you to lose
altitude faster. Now compare best rate of climb; a speed either faster
or slower (Vx) will produce less climb versus time, so although the
best angle for clearing an object at a given distance you will be
going slower then the best rate of climb, but at a steeper angle. It's
that slower speed with less lift that gives you less altitude versus
time.
www.rogerhalstead.com
Old September 26th 06, 12:29 PM posted to rec.aviation.piloting,rec.aviation.student
Dylan Smith
altitude faster.
Not quite - minimum sink (the speed at which you'll lose altitude at the
lowest rate) is slower than best glide.
Yes, the Reply-To email address is valid.
Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de
Old September 26th 06, 10:35 PM posted to rec.aviation.piloting,rec.aviation.student
Andrew Gideon
Right. Which makes best glide and Vy analogous and best loiter and Vx
analogous.
- Andrew
Old September 28th 06, 07:40 AM posted to rec.aviation.piloting,rec.aviation.student
Roger (K8RI)
On Tue, 26 Sep 2006 17:35:51 -0400, Andrew Gideon
Depends on what you are flying. in the Deb Vy is a tad slower than
best glide which gives 500 to 600 fpm while Vx which is a lot slower
gives the express elevator down at about 800 fpm or a tad more.
Gliding at Vx gives me a very fast and steep descent for short field
landings and a bunch of power. In the Deb Vx is definitely not going
to keep you up there longer. Maximum range under power is about the
same as Vy.
analogous.
- Andrew
figuring Rate of Climb Michael Horowitz Home Built 1 June 19th 05 03:16 AM
Newbie question on Rate of Climb Wright1902Glider Home Built 0 August 17th 04 03:48 PM
Rate of climb Dillon Pyron Home Built 3 May 8th 04 01:08 PM
Angle of climb at Vx and glide angle when "overweight": five questions Koopas Ly Piloting 16 November 29th 03 10:01 PM
Minimum rate of climb or descent Aaron Kahn Instrument Flight Rules 3 July 25th 03 03:22 PM
