Replacement altimeter suggestions
Old September 27th 06, 03:19 PM posted to rec.aviation.owning
Default Replacement altimeter suggestions
All I can say is, "CRAP!" The altimeter didn't quite pass the IFR
certification. It had some "erratic" movement, required lots of tapping, and then
would bounce back and forth between the acceptable error limits for the certification.
A couple altitudes were over the limit.
The guy doing the certification said that the altimeter is some off-brand one
that probably cannot be overhauled. (I don't have the nametag in front of me at the
moment). Any ideas on what would be a good place and a good unit to get? He assured
me that so long as it had a calibration sheet with it, the IFR cert doesn't need to be
redone. (Everything else passed.... FINALLY a solid transponder in the plane!)
-Cory
* Cory Papenfuss, Ph.D., PPSEL-IA *
* Electrical Engineering *
Transponder replacement suggestions [email protected] Owning 22 May 12th 06 05:20 AM
Replacement DG & AI: Suggestions? Andrew Gideon Owning 11 April 20th 05 06:09 PM
ATC Altimeter Settings O. Sami Saydjari Instrument Flight Rules 81 April 11th 05 09:07 PM
Local altimeter at BFM Dan Luke Instrument Flight Rules 3 June 15th 04 03:01 PM
Why not use the F-22 to replace the F/A-18 and F-14? Guy Alcala Military Aviation 265 March 7th 04 10:28 AM
