RV-8 What happened?
Old October 7th 06, 05:17 AM posted to rec.aviation.homebuilt
Lady Pilot
Default RV-8 What happened?
Inhofe's Plane Experiences Problems After Landing
POSTED: 12:12 am CDT October 6, 2006
UPDATED: 12:31 pm CDT October 6, 2006
TULSA, Okla. -- A single-engine plane piloted by Sen. Jim Inhofe spun around
after landing at a Tulsa airport, authorities said Thursday.
Neither Inhofe, R-Okla., an experienced flyer, nor his spokesman, Danny
Finnerty, were hurt in the incident, which Finnerty described as "pretty
minor."
Inhofe and Finnerty were returning from a stop in Duncan in southwestern
Oklahoma around 7:55 p.m. when Inhofe's RV-8 prop plane came in for what
seemed to be a smooth landing at Riverside Airport, Finnerty said.
"Everything was as it should be," he said. "Upon landing, everything was
fine before the tail wheel touched down on the pavement. At that point, the
plane got a little squirrely and fishtailed a little."
Roland Herwig, a spokesman for the Federal Aviation Administration in
Oklahoma City, said a preliminary inquiry found that the plane spun around
briefly upon landing.
Finnerty said Inhofe thinks there may have been a problem with the plane's
rudder.
The plane is old-fashioned, with two wheels in the front and one in the
back, Finnerty said.
Any clues?
LP
Old October 7th 06, 05:45 AM posted to rec.aviation.homebuilt
On Fri, 6 Oct 2006 22:17:54 -0500, "Lady Pilot" wrote:
"Roland Herwig, a spokesman for the Federal Aviation Administration in
"Finnerty said Inhofe thinks there may have been a problem with the plane's
rudder.
"The plane is old-fashioned, with two wheels in the front and one in the
back, Finnerty said."
Any clues?
Could be human error, could be mechanical error. The Senator wouldn't be the
first pilot to lose control while landing a taildragger.
As for potential mechanical causes, could be a jammed brake, could be a problem
with the tailwheel itself. We had a Maule at a local airport lose one of the
links that connected the tailwheel to the rudder, a month or two back.
Depending on how the tailwheel control is set up, this could cause the tailwheel
to turn sharply.
Old October 7th 06, 02:28 PM posted to rec.aviation.homebuilt
Capt. Geoffrey Thorpe
"Lady Pilot" wrote in message
news:F%EVg.2323$fl.2292@dukeread08...
around
Ground loops happen.
A taildragger is dynamically unstable because the center of mass is behind
the main gear - get it a little sideways and it wants to continue around all
the way. Perhaps it was the end of a long day and the pilot got a little
behind the aircraft, or..., or... or...
It's kind like parallel parking - some people seem to have a hard time with
it.
Why does something like this even make the paper?
Geoff
Old October 7th 06, 03:13 PM posted to rec.aviation.homebuilt
Mark Hickey
the main gear
Any rear-steer vehicle is inherently unstable, regardless of COG/M
(think "forklift"), more due to the effect on the direction of the
rear wheel as the vehicle turns (essentially, a positive feedback
loop).
I think you left out a couple "ors"... ;-)
it.
Great example!
It's the political silly season. If it comes out that a senator
overcooks his pasta, you'll read about it.
Mark Hickey
Habanero Cycles
http://www.habcycles.com
Home of the $795 ti frame
Old October 7th 06, 03:16 PM posted to rec.aviation.homebuilt
Peter Dohm
"Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com wrote in message
news:IM6dnWZ4Jq0eALrYnZ2dnUVZ_uudnZ2d@wideopenwest .com...
around
all
with
it.
Geoff
There is a tendency for greater interest, and sometimes greater
investivation, when a VIP has been on board.
Sometimes that makes good sense, and other times it can be a waste of
effort--like reading the tabloids at the grocery check-out line.
Peter
Old October 7th 06, 03:24 PM posted to rec.aviation.homebuilt
Peter Dohm
"Ron Wanttaja" wrote in message
around
plane's
rudder.
Any clues?
problem
tailwheel
to turn sharply.
The same has happened down my way.
Tension springs can simply defy inspection--especially on a pre-flight.
Peter
Old October 7th 06, 07:04 PM posted to rec.aviation.homebuilt
John Kunkel
rudder.
Of course the rudder was at fault, would one expect a politician to admit
they could be at fault?
Old October 7th 06, 09:19 PM posted to rec.aviation.homebuilt
Bill Daniels
Nothing was wrong. The Senator just wanted a very fast 360 degree view of
the airport from runway level.
"John Kunkel" wrote in message
plane's
rudder.
Old October 14th 06, 04:40 AM posted to rec.aviation.homebuilt
Lady Pilot
around
True! :-)
plane's
rudder.
I agree now...
Any clues?
Ah, this isn't the first time, or second....if my memory serves me
correctly! ;-)
problem
Thanks,...confirms what I've be thinking... but you *never know*
tailwheel
to turn sharply.
Not the norm...I'm sure! Sorry I haven't answered sooner...major crisis
LP
Old October 14th 06, 04:47 AM posted to rec.aviation.homebuilt
Lady Pilot
around
Of course...I've owned 3 Beech 18 tail draggers...
the main gear -
Are you an aerodynamics engineer? ;-) Many pilots around the world are
"effiencient" in training by a professional.
get it a little sideways and it wants to continue around all the way.
Perhaps it was the end of a long day and the pilot got a little behind the
Or....where are you? heheeheeeee
LP
with it.
Geoff
Has anything happened to Stemme? Martin Gregorie Soaring 4 October 31st 05 12:57 PM
What happened at PAE this Saturday M General Aviation 1 February 1st 05 09:02 AM
What happened at PAE this Saturday M Owning 1 February 1st 05 09:02 AM
Whatever happened to ? Anne Military Aviation 48 May 26th 04 07:47 PM
What really happened to Chuck Noland's plane Mxsmanic Piloting 29 November 7th 03 11:15 AM
