Commodious Sailplane?
Old October 8th 06, 06:44 AM posted to rec.aviation.soaring
Jim[_6_]
Default Commodious Sailplane?
I've been searching for a used sailplane for a month; most are proportioned
for pilots not-so-large as me. Any recommendations for ships with commodious
cockpit dimensions?
Jim Hultman
6'3" 240 lb.
Just call me 'Falstaffian".
Old October 8th 06, 10:49 AM posted to rec.aviation.soaring
Bruce Greef
cockpit dimensions?
Jim Hultman
6'3" 240 lb.
Identical proportions - well same mass and length fits nicely in a Std Cirrus,
and Kestrel.
ASK21 and Grob 103 are also comfortable enough, if not neccessarily what you are
looking for.
Bruce
Old October 8th 06, 01:33 PM posted to rec.aviation.soaring
Dave K
Try an Astir CS. Much better performance than either of these twin
ships. The cockpit is so roomy I used to set up a picnic when I got
hungry during cross-country flights. Lots of room for me and I'm 6' and
200lbs. There was spare movement on the rudder pedal adjustment etc.
Dave Kearns
Bruce Greef wrote:
proportioned
commodious
cockpit dimensions?
Jim Hultman
6'3" 240 lb.
Cirrus, and Kestrel.
you are looking for.
Bruce
Old October 8th 06, 01:45 PM posted to rec.aviation.soaring
I am about the same, a little heavier. I have flown all schweizer
products, Nimbus 3 and Pegasus, both of those without seat pans. Also
LS-4, Standard Cirrus.
Sit before you buy.
Bruce Greef wrote:
proportioned
commodious
cockpit dimensions?
Jim Hultman
6'3" 240 lb.
Bruce
Old October 8th 06, 01:49 PM posted to rec.aviation.soaring
Gary Emerson[_1_]
Genesis has a huge cockpit.
cockpit dimensions?
Jim Hultman
6'3" 240 lb.
Old October 8th 06, 02:10 PM posted to rec.aviation.soaring
I have a Concept 70 - cockpit is as large as they come. I'm 6' and 240,
with several inches of rudder pedal adjustment left.
Ben Jeffrey
"MO"
cockpit dimensions?
Jim Hultman
6'3" 240 lb.
Old October 8th 06, 03:31 PM posted to rec.aviation.soaring
KM
cockpit dimensions?
Jim Hultman
6'3" 240 lb.
Jim, go sit in an ASW-20.Preferably a later model with the flip up
instrument panel.
K Urban
Old October 8th 06, 03:57 PM posted to rec.aviation.soaring
It's surprising what you can fit in if you really want to! I'm 5-10,
about 250, and fit in my LS-6 perfectly. Of course, there is no room
to spare at all - forget folding a sectional inflight - and wearing
heavy clothes for winter or wave flying is probably out of the
question, but for where I fly (shorts and t-shirt, perhaps jeans and a
windbreaker) it works.
Makes it feel like an F-1 race car - no room to rattle around!
Ventus B's and LS-4s are huge by comparison.
A PIK-20, OTOH, is tight - narrow, which makes the flap handle hard to
use; and I haven't found a chute that I can wear in it.
The chute can make a big difference, so be sure include that in your
gear when you try a cockpit on for size.
Good luck!
66
Old October 8th 06, 05:46 PM posted to rec.aviation.soaring
Jim[_6_]
Yes; it's really as much a safety issue as comfort, as flap or spoiler
handles are usually pinned somewhere behind my knee. The stick's
range-of-motion can be impeded as well. The Std. Sirrus sounds good under
$20K. I'm searching out all others mentioned here as well.
Thanks to all who've posted!
Jim Hultman
Good luck!
66
Old October 8th 06, 03:53 PM posted to rec.aviation.soaring
Jim,
You will have no problem fitting comfortably in a Genesis cockpit.
Robert Mudd
cockpit dimensions?
Jim Hultman
6'3" 240 lb.
Jet sailplane update Bob C Soaring 0 April 13th 06 08:06 AM
HpH 304CZ as first sailplane fcnorton Soaring 29 March 31st 06 01:47 AM
Duster Plans For Sale - BJ-1b fullsize sailplane plans WoodHawk Soaring 0 April 25th 05 04:37 AM
Ultralight sailplane aerotow liability Caracole Soaring 18 April 1st 04 09:17 PM
Electro-self-launching sailplane clement Soaring 5 September 12th 03 05:03 AM
