Going of ver recommended TBO
Old October 10th 06, 05:37 PM posted to rec.aviation.piloting
gman
Default Going of ver recommended TBO
Hello All,
Where I fly, the density altitude on the tarmac is typically more than
7000ft even on cold days (9000ft on hot days). As a result, non-turbo
engines cannot develop any more than 70% of rated power.
The consensus around here is that as long as the engines are blessed by
the mechanics and checked for compression, one can exceed the
recommended TBO sometimes by a factor of 2x.
My question is this: Is this practice safe? What about material fatigue
in the engine components (i.e. crank shaft, pistons, rods, valves etc)?
Would this practice make the chances of an engine failure more likely?
Thanks.
Old October 10th 06, 06:22 PM posted to rec.aviation.piloting
Kobra[_3_]
I'm no expert, but it is NOT safe. There are things deep in the engine that
a mechanic has no idea about...such as...the main bearing. If one of those
goes, so does the engine.
As far as cylinders, pistons, rings, valves go...well...they can be
monitored and you can get a "Top Overhaul" to keep those components in
working order. BUT it's the bottom half that really needs the Major
Overhaul. The bearings, seals, crankshaft, cam shaft, connecting rods that
can and will cause an engine failure.
Going over TBO by 50 to 100 hours is one thing...but 1000 or 2000 is totally
an unacceptable risk.
My partner and I fund an Engine Account with 17.00 dollars per hobbs flying
hour. We have 12,000.00 dollars in that account now with 800 hours left to
go. When we hit 2000 we will have 90% or more of the money for an overhaul.
Don't stick your head in the sand and fly, fly, fly and never save for the
overhaul. You'll only be fooling yourself that when the time comes you'll
have the money or that you'll get 4000 hours out of that engine. It won't
happen. The next time you blink you'll be at TBO and no way to replace the
engine. Then you'll be forced to sell the plane for much less than you
bought it for.
Kobra
Old October 10th 06, 06:30 PM posted to rec.aviation.piloting
Doug[_1_]
The altitude does help because it limits power developed by the engine
and that causes wear. Safe? As the engine ages, the chances of a
breakdown increase. There is an increased chance of a breakdown
immediately after rebuild also. The 2000 hours is not regulatory for
Part 91 aircraft and many owners exceed it. Even Part 135 operators can
exceed it if they get a waiver from the FAA (and they can if they
monitor their engines and get it all approved etc). YOU will have to
decide where your level of risk is. But I would think some hours past
2000, perhaps 500 would be economic and not incur signifigant
additional safety risks. Cut open your oil filters and do oil analysis
and keep an eye on oil consumption, and do frequent compression checks.
Any anamolies with those tests indicate time to rebuild (if you are
past TBO). Good luck!
gman wrote:
Hello All,
Thanks.
Old October 10th 06, 07:23 PM posted to rec.aviation.piloting
Robert M. Gary
Wow, I don't know about a factor of 2x. I think the most important
factors are
1) How recent was the last overhaul
2) What the engine factory overhauled, new, or field overhauled last?
I know some operators that go as much as 300 hours past TBO but they
reach TBO every few years. An engine that has been 20 years since
overhaul is probably due before TBO, regardless of how its run.
Also, I would expect a factory new engine would do better past TBO than
a field overhauled.
I have a factory new engine installed in 97. I expect to be able to go
about 200 hours past. However I have the following going for me 1) It
was factory new 2) It has only been 10 years and 3) I have a complete
record of oil analysis since installation.
-Robert
Old October 10th 06, 07:36 PM posted to rec.aviation.piloting
Tony Cox
"gman" wrote in message
The Oct '06 edition of "Light Plane Maintenance" fielded
a question on exceeding TBO with a Lycoming O-320
in a Cessna 172 (you didn't say what engine you have).
The engine burns 1qt/8 hours and the compressions are
all in the low 70s. The owner recently did a valve wobble
check.
Biggest concern: exhaust valve break up, which apparently
nearly always happens in flight, but which is usually
preceded by said valve getting burnt, then getting hot, and
then failing.
Recommendation: Continue flying until engine gives a
reason for overhaul. Increase monitoring, especially by
doing frequent compression checks (25 hours) and attention
to oil (filter/screen + oil analysis). Compression check
verifies both cylinder & valves not seating properly. Investigate
if any cylinder showing compression in the low 60s.
Old October 10th 06, 08:12 PM posted to rec.aviation.piloting
Jim Macklin
Wear and friction are not less because the power output is
reduced at altitude. Bearing wear increases clearances and
oil pressure will decrease. You can detect some of the wear
by careful inspection of an assembled engine. There are
some things that can't be checked without engine
disassembly. If you tear the engine down, you might as well
complete the overhaul.
TBO is only mandatory in commercial operations. Because of
the cost of being sued, most FBO do overhauls at TBO because
juries decide. Private owners are free to do what they
want. Compression can be checked and since aircraft engines
use individual cylinders, rings and valves can be repaired
one cylinder at a time as required. That does not alter TBO
time.
Overhaul includes all components and accessories, such as
magnetos. A freshly overhauled engine [or a new one] is
suspect for the first 100 hours.
James H. Macklin
ATP,CFI,A&P
| Hello All,
typically more than
result, non-turbo
are blessed by
material fatigue
valves etc)?
more likely?
| Thanks.
Old October 10th 06, 08:32 PM posted to rec.aviation.piloting
Ron Natalie
gman wrote:
Hello All,
TBO is advisory only for non-commerical operators. Flight school
aircraft that are flown and maintained regularly, even down here
at sea level, typically will make TBO without working hard. We
had a skyhawk here that was still going strong at 2400 hours SMOH.
It had spent the first 2000+ hours as an Embry Riddle plane and
then the next 3000+ or so in a well-run club. It's still flying
traffic reports in the DC area.
Most privately owned aircraft that fly 100-200 hours a year aren't
going to make it to TBO without a lot of luck.
Old October 10th 06, 09:31 PM posted to rec.aviation.piloting
NW_Pilot
Hello All,
Thanks.
I would rather fly a over tbo engine with a clean bill of health & good oil
analysis trend than a freshly overhauled or factory new engine with 0 hours!
Old October 10th 06, 09:56 PM posted to rec.aviation.piloting
Jim Macklin
Agreed, the first 100 hours are all a test flight for
material and workmanship.
James H. Macklin
ATP,CFI,A&P
"NW_Pilot" wrote in
message . ..
| Hello All,
typically more than
result, non-turbo
are blessed by
exceed the
material fatigue
rods, valves etc)?
| Thanks.
health & good oil
Old October 11th 06, 12:39 AM posted to rec.aviation.piloting
Paul Tomblin
Our flying club aircraft regularly make 2400 or more hours, although our
Warrior only made 1800. Our Lance currently has 2700 hours on its IO-540.
Club aircraft get lots of hours, over the whole year, so that helps keep
the rust off. Plus, they're well maintained, and flown by people who
treat the planes like they own them.
When an engine is getting near to or over TBO, we do an oil analysis every
oil change instead of every other to see if it starts making metal, and we
watch compressions.
Paul Tomblin http://blog.xcski.com/
My name is *ozymandias[], array of arrays
Look on my stack trace, ye mighty, and despair.
Recommended source for 4130 sheet and tubing? Michael Horowitz Restoration 3 April 16th 06 08:23 PM
Anywhere recommended near Rochester MN? Dave General Aviation 0 April 8th 04 12:48 PM
Anywhere recommended near Rochester MN? Dave Aerobatics 0 April 7th 04 04:46 PM
Anywhere recommended near Rochester MN? Dave Aerobatics 0 April 1st 04 06:18 PM
