Why are the yokes always turned?
Old October 16th 06, 07:03 AM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Default Why are the yokes always turned?
Why does it seem that the control yokes of small aircraft are always
turned completely to one side or the other in photographs? Is there
some sort of convention about doing this? A safety reason? Why is it
so common?
Old October 16th 06, 07:09 AM posted to rec.aviation.piloting,rec.aviation.student
Wade Hasbrouck
"Mxsmanic" wrote in message
so common?
If it is during taxi operations... It is so that the wind doesn't get under
the wing and flip the plane over... Basically "Quartering headwind, turn
into it, quartering tailwind, turn away from it and elevator forward."
Old October 16th 06, 07:12 AM posted to rec.aviation.piloting,rec.aviation.student
EridanMan
There is a standard practice of looping the pilot's seatbelt through
the yoke and latching it on non-cessna aircraft (or any plane that does
not have a built-in controll locking mechanism), this pulls the yoke
all the way back and over, and might be what you're describing.
It actually isn't the best practice, its hard on the yoke... There are
several after-market control locks for airplanes that don't have them
built in, but they can be hard to find.
A Control lock is a device which holds the controls of the aircraft so
they do not bang around if winds gusts. The practice above is
essentially using the seatbelt to do the same thing.
Cessna's have a hole in the pilot's side yoke shaft in which you put a
peg that bends around and covers the magneto switch (so you can't
accidentally start with the control lock in place). Its a very simple,
functional system... not sure why other aircraft makers didn't use it
too (I'm sure other AC makers use other systems as well I dont' know
about).
so common?
Old October 16th 06, 07:41 AM posted to rec.aviation.piloting,rec.aviation.student
so common?
I've never seen this. Can you post a link to some examples?
Old October 16th 06, 08:05 AM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Wade Hasbrouck writes:
OK. I neglected to mention that the photos I've seen were normally of
aircraft that were parked. I'll make a note of the adjustments for
taxi.
Old October 16th 06, 09:54 AM posted to rec.aviation.piloting,rec.aviation.student
Jim Macklin
Often the ailerons are connect to the rudder with a bungee.
The rudder is connected to the nose wheel steering. Ergo.
"Ron Wanttaja" wrote in message
aircraft are always
reason? Why is it
| so common?
examples?
| Ron Wanttaja
Old October 16th 06, 01:10 PM posted to rec.aviation.piloting,rec.aviation.student
Ron Natalie
so common?
Without any airflow over the ailerons, it's kind of hard to hold
them in the center. As soon as the control flops over to one
side or the other, it tends to stay there.
Old October 16th 06, 01:45 PM posted to rec.aviation.piloting,rec.aviation.student
Viperdoc[_1_]
There are usually slight differences in weight between the control surfaces,
due to the manufacturing process. For example, it is not uncommon for one
aileron to be a pound or two heavier than the other.
Gravity, plus the force of winds, will inevitably cause one to droop.
Likewise, rudders are not always hinged in a straight line, and the hinge
lines are off center, so the rudder will tend to tilt toward the heavier
side.
This is simply a factor in owning planes that are frequently over 20+ years
old.
Old October 16th 06, 03:21 PM posted to rec.aviation.piloting,rec.aviation.student
Jim Burns[_1_]
It's for photo purposes. Usually to allow an unobstructed view of the
panel.
Old October 16th 06, 05:50 PM posted to rec.aviation.piloting,rec.aviation.student
buttman
about).
I know some manufactures no longer make control locks for liability
reasons. People would try to take off with the control lock still in
place and crash; then sue the manufacturer. Seems really stupid, but
thats what I heard.
rivet squeezer yokes Jim Burns Home Built 13 May 4th 06 02:52 PM
1966 Cessna 172 Control Yokes --- What Alloy? jls Home Built 0 November 4th 04 06:02 PM
Helicopter exercise turned scary: report Otis Willie Military Aviation 0 July 5th 04 02:43 AM
Anyone wrapped their yokes in leather? Jay Honeck Owning 13 March 3rd 04 03:59 PM
Vintage Cessna Yokes Al Gilson Owning 8 September 12th 03 04:27 PM
