Fuel servo problem???
Old October 18th 06, 08:37 PM posted to rec.aviation.piloting,rec.aviation.owning
Robert M. Gary
Default Fuel servo problem???
Today I went out to my plane to fly and found a very odd problem. When
I started the plane after taxiing over the fuel, I could only get it to
run when the mixture was just at the edge of idle cut off. Moving it
even 1/8 forward caused the engine to die right away.
I did some diagnostics. At 1500 RPM I was getting 22lbs of fuel
pressure (normal) and 5GPH in fuel flow (very high). As I moved the
mixture about 1/8 forward that jumped to about 6GPH until the engine
started to die. Running at 2000RPM moving the mixture control to 1/4
caused the engine to totally die.
I run the engine like this for about 20 minutes to make sure it was hot
but no improvement. I even stalled it several times (by moving the
mixture to 1/4 rich) and restarted it. Each restart required 2 seconds
of fuel boost so I don't think it was flooded.
On one restart it ran totally fine, and I was getting about 3.0 GPH at
1500 at 1/4 mixture and about 3.8GPH at 2000 RPM at full rich. So I
shut down again and tried it again and it was having the problem again,
running about 5GPH at 1500 RPM with mixture at the edge of cut-off.
The only thing I can think if is it would be a fuel servo issue. It
seems a little bit intermitant but I seem to be able to make it happen
often enough. Sadly, I'm not at the airport where I normally have
maintenance done and I don't want to fly it now. I've been told to
expect approx $3000 to OH the fuel servo. This is for an IO-360-A3B6
engine.
-Robert
fuel leak or auxiliary fuel pump malfunction? [email protected] Owning 7 December 17th 06 01:57 PM
Jet fuel A-1 specific gravity [email protected] Piloting 7 May 20th 06 05:39 PM
Most reliable homebuilt helicopter? tom pettit Home Built 35 September 29th 05 03:24 PM
RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) Snowbird Owning 77 December 3rd 03 10:10 PM
Cherokee Six Fuel problem EDR General Aviation 1 August 15th 03 04:03 PM
