Tow Hitch Ball - 50mm or 2"?
Old October 27th 06, 10:06 PM posted to rec.aviation.soaring
ContestID67
Default Tow Hitch Ball - 50mm or 2"?
I needed to move a Blanik L23 trailer over the weekend. Using my 2"
tow hitch ball and I had a heck of a time disconnecting the two. I
knew that the Blanik trailer has what I assume is a 50mm tongue.
I was kind of surprised that my 2" ball (which works out to be 50.8mm)
would be a problem disconnecting. 8/10's of a millimeter difference
doesn't seem like enough to worry about.
What is the tolerance on a 2" setup? Is it so close that 0.8mm can be
a problem?
Thanks, John
Coordinated turns and the little ball Mxsmanic Piloting 51 October 11th 06 11:17 PM
Wanted - Ball Vario parts [email protected] Soaring 0 September 22nd 06 06:56 AM
Why don't wings have dimples? Dancing Fingers Home Built 56 June 18th 06 12:54 AM
wanted L'Hotellier ball fitting assembly Udo Rumpf Soaring 3 January 7th 05 04:05 AM
Trailer hitch inadvertant disconnect Bill Daniels Soaring 5 July 16th 04 04:17 AM
