Thermalling the D2
Old October 31st 06, 02:26 AM posted to rec.aviation.soaring
Fox Two
Default Thermalling the D2
Hi All!
I'm currently a Discus CS driver with a new D2-b coming in about 3
months from the factory. I've found that thermalling the CS with the
yaw string slightly high in the turn yields a better climb - I'm
curious to hear about thermalling techniques from the D2 veterans.
Thanks in advance!
Chris, F2
Old October 31st 06, 07:10 PM posted to rec.aviation.soaring
raulb
I have never flown a Discus, nor anything close, but when I was
learning to fly 23 years ago, my instructor told me to keep a little
top rudder in turns and when thermalling. I tried to keep that in mind
but it was not until I transitioned to glass years later that I really
discovered why: slipping a little makes centering the thermal easier
and that results in better climb. This has been true whether I was
flying a 2-33, 1-34, BG-12, even a T-31, but it is especially noticable
in my LS-1.
Fox Two wrote:
Hi All!
Thanks in advance!
Chris, F2
Old October 31st 06, 07:49 PM posted to rec.aviation.soaring
Greg Arnold
in my LS-1.
Dick Johnson wrote a SOARING article about this that is on the SSA
webpage (members only). There seems to be some question about how much
of a slip is desirable when a glider has winglets, since the winglets
could have an excessively low or high angle of attack.
Fox Two wrote:
Hi All!
Thanks in advance!
Chris, F2
Old October 31st 06, 09:34 PM posted to rec.aviation.soaring
Mike the Strike
Of all the gliders I have flown or owned, the one that really seemed to
benefit from a bit of top rudder was my ASW-20. Anecdotal evidence
suggests that winglets help in thermals and reduce the need for this
little slip.
I find my D2 seems to ride on rails in thermals, probably because of
the double dihedral and winglets, and I just keep the yaw string
centered. You may find the nose-high attitude of the D2 will take some
getting used to.
Enjoy your new ship!
On Oct 30, 6:26 pm, "Fox Two" wrote:
Hi All!
Thanks in advance!
Chris, F2
Old November 1st 06, 02:16 AM posted to rec.aviation.soaring
Chris:
Now all you need is; A D2b, and B thermals.
Zulu
Old November 2nd 06, 10:42 AM posted to rec.aviation.soaring
Ben Flewett
Chris,
The D2 definitely has to be slipped in the turn. Ask
Davis or Darroze and they will confirm this.
Just fly it EXACTLY the same way you would fly your
Discus CS.
Cheers,
Ben
really seemed to
evidence
the need for this
little slip.
because of
yaw string
D2 will take some
getting used to.
On Oct 30, 6:26 pm, 'Fox Two' wrote:
Hi All!
in about 3
the CS with the
climb - I'm
the D2 veterans.
Thanks in advance!
Chris, F2
Old November 2nd 06, 05:27 PM posted to rec.aviation.soaring
Mike the Strike
I just reviewed a couple of cockpit photos I took of my D2 thermalling
and note that the yaw string in both cases shows about a 10 degree
slip.
While flying, I haven't noticed that I needed to deliberately keep this
slip and wonder if this is the way the ship just sits. Or perhaps I
just fly it that way without thinking?
On Nov 2, 2:42 am, Ben Flewett
Chris,
Discus CS.
Cheers,
Ben
really seemed to
evidence
the need for this
little slip.
because of
yaw string
D2 will take some
getting used to.
Hi All!
in about 3
the CS with the
climb - I'm
the D2 veterans.
Thanks in advance!
Chris, F2
Old November 2nd 06, 09:15 PM posted to rec.aviation.soaring
P Ilatus
I read an article which mentioned that the only way
you could really tell via yawstring if in a slip was
if it was placed at the CG.
by positioning the string forward, i.e., on the canopy,
one could expect it to show a small amount of error.
I find that my b likes to climb in a slight skid for
some reason. sounds weird (and a bit dangerous) but
works for me
my D2 thermalling
a 10 degree
slip.
keep this
Or perhaps I
Chris,
Ask
Discus CS.
Cheers,
Ben
that
really seemed to
evidence
the need for this
little slip.
because of
yaw string
D2 will take some
getting used to.
Hi All!
coming
in about 3
the CS with the
climb - I'm
the D2 veterans.
Thanks in advance!
Chris, F2
Old November 2nd 06, 11:01 PM posted to rec.aviation.soaring
Bill Daniels
I constructed a to-scale CAD drawing of a glider in a very agressive 300
foot diameter turn and looked at the angle difference between a nose and a
CG yaw string. - it's something like a 1/100 of a degree. The difference is
so small you'd never see it. In fact, it's likely that any difference
would be swamped by local turbulent flow.
Bill Daniels
"P Ilatus" wrote in message
works for me
my D2 thermalling
a 10 degree
slip.
keep this
Or perhaps I
Chris,
Ask
Discus CS.
Cheers,
Ben
that
really seemed to
evidence
the need for this
little slip.
because of
yaw string
D2 will take some
getting used to.
Hi All!
coming
in about 3
the CS with the
climb - I'm
the D2 veterans.
Thanks in advance!
Chris, F2
Glider Crash - Minden? Mitch Soaring 141 September 13th 06 08:31 PM
Libelle thermalling techniques AdamLibelle Soaring 6 September 5th 06 07:40 PM
The new art of thermalling - with a kite... [email protected] Soaring 3 July 30th 06 05:06 AM
Bronze Badge question [email protected] Soaring 32 January 11th 06 10:19 PM
Hands off thermalling John Jones Soaring 24 April 26th 04 04:07 PM
