Source of large diameter thick wall tube
Old November 1st 06, 09:49 PM posted to rec.aviation.homebuilt
Bill Daniels
Default Source of large diameter thick wall tube
This request isn't exactly for an airplane but it's for a glider winch.
I need to find a source for small amounts of 6.5" OD 1" wall steel tube. I
don't care too much about the alloy as long as it's reasonably strong and
both machinable and weldable.
Thanks in advance.
Bill Daniels
Old November 1st 06, 11:22 PM posted to rec.aviation.homebuilt
Rich S.[_1_]
"Bill Daniels" bildan@comcast-dot-net wrote in message
I don't care too much about the alloy as long as it's reasonably strong
and both machinable and weldable.
Try Floyd Equipment
2208 Pacific Highway E.
Fife, WA
253.922.0200
That's where I get the tube for my cannon barrels.
Rich S.
Old November 2nd 06, 01:30 AM posted to rec.aviation.homebuilt
John Ammeter
Ya know, I was thinking that the tubing he was describing would make a
really good cannon myself...
John
Try Floyd Equipment
Fife, WA
253.922.0200
Rich S.
Old November 2nd 06, 01:47 AM posted to rec.aviation.homebuilt
Bill Daniels
Well, it would be kinda short at 6" long. In cannon terminology, that would
be a 6-1. (The first number is the bore in inches and the second is the
barrel length in multiples of the bore.)
As I mentioned in a post a couple of years ago, a 30 foot length of 5" drill
pipe capped on one end and filled with a mix of oxygen and acetylene then
set off with a spark will do a reasonable imitation of a Naval 5-38. I know
that because a bunch of very bored roughnecks showed me. ( I also remember
what REAL Navy 5-38's sound like.)
I really don't need much thick wall tube.
Bill Daniels
"John Ammeter" wrote in message
news:7dOdnYkgrsq2odTYnZ2dnUVZ_uWdnZ2d@cablespeedwa .com...
John
Try Floyd Equipment
Fife, WA
253.922.0200
Rich S.
Old November 2nd 06, 04:06 AM posted to rec.aviation.homebuilt
Doug Palmer
You might want to try Alan Steel in Redwood City, CA They have a lot of odd
sizes
DP
Thanks in advance.
Bill Daniels
Old November 2nd 06, 04:29 AM posted to rec.aviation.homebuilt
GeorgeB
On Wed, 1 Nov 2006 13:49:46 -0700, "Bill Daniels"
Thanks in advance.
Bill Daniels
Bill, when I worked in heavy industry, our shop would regularly order
"structural tubing" from our steel supplier. It might have taken a
week or 2, but we never had any problem getting just about any size we
wanted.
That said, have you given any thought to 6" XXS pipe which will be
6.625 OD with 0.864 wall? I don't know if your dimensions were
generic or specific (as in fitting bearings). IF the latter, that
pipe, with OD machined to the bearings at the ends, may work; I'm not
a good enough engineer to do the calculations.
Schedule 160 may be easier to find; wall is 0.718.
George
Old November 2nd 06, 11:21 PM posted to rec.aviation.homebuilt
Lou
Don't be rediculous, it's to hold the football for field goal attempts.
6061-T6 2"x4" rect tube source? Mr.TwistAir Home Built 8 December 11th 05 05:59 AM
Boeing Boondoggle Larry Dighera Military Aviation 77 September 15th 04 03:39 AM
NEED: Source for Aluminum Bar 1 Inch thick 4 Inches Wide [email protected] Home Built 4 March 16th 04 11:11 PM
Source for Aluminum Bar 1 Inch thick 4 Inches Wide Jon Ritter Home Built 2 March 9th 04 02:40 PM
NEED: Source for Aluminum Bar 1 Inch thick 4 Inches Wide [email protected] Aviation Marketplace 0 March 7th 04 05:06 PM
