Low compresion 500 hour Cylinder outcome
Old November 8th 06, 12:32 AM posted to rec.aviation.owning
A Lieberma
Default Low compresion 500 hour Cylinder outcome
Well, it had to be pulled and sent to the shop for overhaul. A&P thinks
the valve guides need redone (calibrated?).
Took 'er up around the pattern to see if the compressions would come up
from a hard run, and for the first 4 take offs and landings, engine
performed wonderfully. 35 minutes later and the fifth time on downwind,
engine started missing, so needless to say, made a very short approach to
landing. What a better time to practice spot landings :-)
So to answer the question whether high RPMS fix compression issues, in my
experiences, it did not.
Compressions were 30 after that jaunt. Cylinder pulled and sent to Holly
Springs MS for service. Will get it back hopefully Thursday and be back in
the air on Friday.
I watched the A&P pull the cylinder and the rings were not frozen, they
seem to move freely to me. Minor dark coloring on the side of the piston
head, some carbon on the top (I ran full rich, not surprised or alarmed).
Cylinder walls were sparkling clean throughout except near the top part
where the piston meets the spark plug. Some dark coloring in that area.
Still amazes me how such precision is designed in a area of the engine that
beats itself up :-)
Allen
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 03:55 AM
Bad cylinder Denny Owning 17 September 12th 05 06:04 PM
Path of an airplane in a 1G roll Chris W Piloting 47 July 4th 05 10:53 PM
Path of an airplane in a 1G roll Chris W Aerobatics 20 June 29th 05 09:35 AM
Path of an airplane in a 1G roll Chris W Home Built 22 June 29th 05 09:35 AM
