Soreness after flights, and rudders
Old November 14th 06, 09:28 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Default Soreness after flights, and rudders
Does flying leave you sore if you haven't flown in a while or if you
are new to flying? I'm thinking of muscle fatigue from being in an
unusual position for long periods, and in particular I'm wondering if
keeping one's feet on rudder pedals for hours at a time leads to any
soreness afterwards. Or do you even keep your feet on the pedals all
the time? Since apparently most autopilots don't use the rudder, even
running on autopilot might not eliminate the need to have feet on the
rudder (?). And if pushing the pedals forward applies the brakes,
does this mean that you have to hold your foot back whenever it's
resting on the pedal? Does it hurt anything to apply the brakes in
flight?
Old November 14th 06, 09:48 PM posted to rec.aviation.piloting,rec.aviation.student
Robert M. Gary
flight?
Not much reason to touch the rudders in straight and level flight. My
plane has an interconnect too so the rudders happen automatically when
I use the ailerons (nearly all high performance planes do). Its not
much different than sitting in a car exept that you don't get the
fatigue of having to watch the road.
The rudder has nothing to do with the brakes. I wouldn't touch the
brakes while the gear is retracted. Probably ok, but I wouldn't mess
with it. The rudders are lighter when the gear is up anyway since you
aren't moving the nose wheel.
-Robert
Old November 14th 06, 09:53 PM posted to rec.aviation.piloting,rec.aviation.student
Jay Honeck
the time?
Nope. Most spam cans are stable in level flight, and -- since most
flight is level -- your feet can remain firmly planted on the floor.
The only time my feet are on the rudders is during take-offs, landings,
and maneuvers.
flight?
One thing I've noticed with the CH pedals that we bought for the Kiwi
(our flight sim) -- it's too easy to fly around with the toe brakes on.
It's something to do with the angle they're mounted at, and -- even
with them permanently mounted in the Kiwi at a more accurate angle, it
still happens all the time.
Real aircraft rudders (that have toe brakes) don't work that way, so,
no, you don't have to hold your toes back whenever your feet are
resting on the pedals.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old November 14th 06, 11:05 PM posted to rec.aviation.piloting,rec.aviation.student
VH-UNR
flight?
For a new pilot, while your on the ground yes, your claves can become
sore, because your whole foot is on the rudder peddle, thats if you
have toe brakes. once your ready to take off, as my instructor says,
part of your pre-takeoff checklist should inclue a saying, heels on
floor. The rudder becomes extremely responsive once you start you run
up and you should only be placing you balls of your feet on the pedel
to control them, still resting your heels on the floor. This is very
important during the takeoff roll as your really do not want to hit
them brakes. as the other guys said, if your ot having to balance a
turn or manouver then you can take you feet of the rudder.
Old November 14th 06, 11:38 PM posted to rec.aviation.piloting,rec.aviation.student
Robert M. Gary
You probaby don't want to have your foot on the brake on the ground
unless you actually mean to use the brake. I teach my students to taxi
with their feet flat on the floor because they would otherwise always
drag the brakes during taxi. Most people seem to want to use brake to
control taxi speed rather than power, which is not a good habit.
-Robert, CFII
Old November 15th 06, 12:37 AM posted to rec.aviation.piloting,rec.aviation.student
VH-UNR
-Robert, CFII
we teach you to have your whole foot on the rudder whilst on the
ground. its a safetly thing here. there is a tendency for animals,
people, natives to run onto taxiways, plus we need to negotiate some
sharp turns that the nose wheel of the C172 cant get round without
assistance from the differential brakes. But its a personal thing for
us. Some guys will teach the same as you. i just tell the students that
if they ride the brakes, and a fire starts, then they can pay the
damage.
Old November 15th 06, 01:43 AM posted to rec.aviation.piloting,rec.aviation.student
mike regish
On one of my landings during dual, the Cessna 150 I was in was shaking like
crazy during a TnG. I couldn't figure it out and neither could my
instructor. It felt like a really rough paved strip, but we both knew it
wasn't quite THAT rough. I finally figured out (probably days later) that I
must have had my toes on the brakes by accident. My feet were just too high
up on the pedals. No damage, but I'm kind of surprised that my instructor
hadn't thought of that. Seems like it could be a pretty common problem.
mike
-Robert, CFII
Old November 15th 06, 02:57 AM posted to rec.aviation.piloting,rec.aviation.student
VH-UNR
Hence Why we say, heels on the floor. I get the students to say it out
loud as they line up.
mike
-Robert, CFII
Old November 15th 06, 03:01 AM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Jay Honeck writes:
and maneuvers.
Does placing your feet back on the pedals cause any movement in the
rudder, or is it more resistant to inadvertent movement than that?
Yes, that seems to be a problem with sim pedals. You can set the dead
zone higher on the brakes to avoid actually having them applied, but
you might still be pressing forward on the pedals.
So how do they work? You have to extend your foot (press the toes
forward) to apply the brakes, right? Which in turn implies that you
might have to deliberately hold the tip of your foot back in order to
avoid applying the brakes. I've always wondered about that.
Old November 15th 06, 03:03 AM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
VH-UNR writes:
Hmm ... I didn't think of that. In pictures it looks like the pedals
are raised considerably off the floor. I've had trouble visualizing
exactly how the pilot's feet fit on the pedals. Pictures of the
pedals aren't very clear, and I've never seen a photo that shows how
the pilot puts his feet on the pedals.
