Zander SR800 problem
Old December 27th 06, 06:48 PM posted to rec.aviation.soaring
Ian[_1_]
Default Zander SR800 problem
Hi All
After many years good service, our Zander SR800 Vario/Glide Computer has
developed a fault.
It reads 7m/s lift when the glider is on the ground. When the range
switch is moved from 0-10 to 0-5m/s it goes off scale. The digital
averager slowly climbs till it reads 13 m/s. The audio makes a click when
you switch the unit on but after that there are no sounds.
I have taken it out the glider and had a look at it. There are no obvious
faults like loose connections. When the zero set adjustment potentiometer
is turned it makes no difference to the indicated reading.
Has anybody seen anything like this before?
Does anybody have any suggestions for getting it repaired?
This is an excellent vario. But the computer does not interface with
GPS's or PDA. (I think it may even be an analogue device). I fear it is
not worth spending too much effort on fixing it. So my next post will be about
possible replacements.
Thanks
Ian
So...about that plane on the treadmill... Ray Piloting 135 December 18th 06 11:30 PM
Problem with Unison Lasar Ignition hmoser Home Built 2 December 2nd 06 03:10 PM
SSA Website problem Raphael Warshaw Soaring 2 February 12th 04 03:56 PM
RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) Snowbird Home Built 78 December 3rd 03 10:10 PM
Problem: Ground Speed Estimate with Volkslogger and WinPilot RamyYanetz Soaring 3 August 26th 03 04:06 PM
