VNAV placard in DA-40, and pedal adjustment?
Old January 2nd 07, 06:00 AM posted to rec.aviation.owning
Roy Smith
Default VNAV placard in DA-40, and pedal adjustment?
There's a cockpit photo of a DA-40 (http://tinyurl.com/yxju4u), there is a
placard just below and to the right of the right-hand MFD. I can't quite
read it, but I think it says "Use of VNAV Is Prohibited". Is that indeed
what it says? And, if so, why?
Second question -- I understand you don't adjust the seat in the DA-40, but
you adjust the ruder pedals. How do they adjust? Do you need to crawl
under the panel, or is there some easy-to-reach control that you can adjust
without having to be a contortionist?
Need Grob 103 Twin II left front rudder pedal Mike McCarron Soaring 1 May 15th 06 03:16 PM
ASA OnTop 8 Pedal Problem Kevin Instrument Flight Rules 1 August 21st 03 06:42 PM
