Oil pressure problem
Old January 3rd 07, 11:13 PM posted to rec.aviation.piloting
Aluckyguess
Default Oil pressure problem
I have a Bonanza V35 with a IO 470. Before and after engine overhaul the oil
pressure after the engine warms up goes just into the red. They have tried
turning the pressure up but this seems to only make the pressure go up when
cold. If the temperature outside is real cool the pressure goes over 200
psi. The engine builder said its in spec. I think there is a problem
somewhere. I want the oil pressure to run in the green. Does anybody have
any ideas on what could be causing this. I'm afraid its going to blow the
gage out one cold morning.
Thanks
So...about that plane on the treadmill... Ray Piloting 135 December 18th 06 11:30 PM
Jet engines vs. leaf blowers 01-- Zero One Soaring 6 September 8th 05 02:59 AM
High Oil Pressure (was: Low oil pressure, high oil temp?) Thomas Ploch Owning 4 October 5th 04 05:34 AM
Why are TE probes so long? Duane Eisenbeiss Soaring 36 May 9th 04 07:58 AM
Manifold pressure gauge problem Dave Russell Aerobatics 3 January 29th 04 04:46 AM
