Garmin 330TXP temp probe pictures
Old January 7th 07, 10:32 PM posted to rec.aviation.owning
karl gruber[_1_]
Default Garmin 330TXP temp probe pictures
Some of you wanted to see the variable resistor in the line out to the temp
probe. As most have found, the probe does not transmit the proper temp. Here
they a
"Curator"
http://temp.corvetteforum.net/c5/kgr...7__medium_.jpg
http://temp.corvetteforum.net/c5/kgr...8__medium_.jpg
http://temp.corvetteforum.net/c5/kgr...9__medium_.jpg
http://temp.corvetteforum.net/c5/kgr...0__medium_.jpg
Old January 8th 07, 01:52 AM posted to rec.aviation.owning
mikem
Karl,
I must have missed the earlier post. What is the issue with the OAT
probe?
Old January 8th 07, 04:31 AM posted to rec.aviation.owning
karl gruber[_1_]
As supplied, it isn't calibrated.
Karl
"mikem" wrote in message
ps.com...
temp
Karl,
probe?
Old January 8th 07, 10:00 AM posted to rec.aviation.owning
Thomas Borchert
Karl,
probe.
As I said in my mail to you already: Thanks a lot!
Do you happen to know any resistance values printed on the thing?
Thomas Borchert (EDDH)
Old January 8th 07, 04:10 PM posted to rec.aviation.owning
karl gruber[_1_]
I'll ask Jack, next time I see him.
"Curator"
"Thomas Borchert" wrote in message
Karl,
temp
probe.
Old January 8th 07, 05:53 PM posted to rec.aviation.owning
Thomas Borchert wrote:
the temp probe.
I don't know what resistance it is, but I'll add that it looks like a
multi-turn trimpot, maybe 15 turns. This lets you adjust it more
closely, and also these type of trimpots are usually sealed a little
better. This kind of trimpot is maybe US$2 at a large electronics
supplier. (The more common types of trimpot are usually less than one
full turn, maybe 300 degrees, and are usually not sealed very well.)
You could work out the appropriate resistance by measuring the
resistance of the temperature sensor at various known temperatures and
coming up with a value of "degrees per ohm". Note that the resistance/
temperature relationship of the sensor may or may not be linear.
Also, depending on the sensor, adding a series resistor probably only
lets you correct the reading (reliably) in one direction. You could
add a parallel resistor but I don't think this would work very well,
depending on the range of temperatures you want to measure.
Disclaimer: This is based on experience with electronics in ground
applications. I don't have an A&P; I don't even have a TG&Y. Your
mileage may vary.
Matt Roberds
Garmin 530 WAAS? Al G Instrument Flight Rules 53 November 21st 06 11:30 PM
CHT probe + resistor installed (final) Jim Burns Owning 8 September 10th 05 02:34 PM
Pirep: Garmin GPSMAP 296 versus 295. (very long) Jon Woellhaf Piloting 12 September 4th 04 11:55 PM
Amateur Review of the Garmin GPSMAP 296 GPS Rhett Products 10 April 29th 04 06:57 AM
carb temp probe Philippe Vessaire Home Built 1 September 20th 03 08:21 AM
