Determination of bank angle from speed and heading change per time period
Old January 9th 07, 09:58 AM posted to rec.aviation.piloting
Grumman-581[_1_]
Default Determination of bank angle from speed and heading change per time period
Anyone know of a formula for determing the current bank angle, given the
current velocity and rate of change in heading over a particular period of
time? I was thinking of adding an artificial horizon to program that I'm
working on and figured that by taking the current velocity as reported by
the GPS and the change in heading as reported by the last two
course-over-ground measurements from the GPS, I should be able to
determine a close approximation of the actual bank angle... Of course,
this assumes that the current winds are ignored in addition to assuming a
coordinated turn... The current system that I am using only gets updates
at 1 Hz which might be a bit low, but I'm thinking of getting the Garmin
18 5 Hz unit which should be sufficiently fast in its update rate...
Old January 9th 07, 02:03 PM posted to rec.aviation.piloting
d&tm
"Grumman-581" wrote in message
news
bank angle = tan ^-1 ( 2*PI*v / g *t )
v= velocity
g= gravitational acceleration
t = time for 360 degree turn rate
PI =3.14159
make sure you use consistant units for v, g and t
for SI use v in m/s
g = 9.8 m/s^2
t in seconds
in imperial g = 32 ft /s^2 ( If I remember correctly)
v in ft/sec
t in sec
Terry
PPL downunder
Old January 9th 07, 02:17 PM posted to rec.aviation.piloting
Bob Moore
the current velocity and rate of change in heading over a particular
period of time?
I think that you are going to have to work with TAS instead of GS,
but Figure 2.29 on page 179 of Aerodynamics for Naval Aviators has
a graph of all the factors involved.
Bob Moore
Old January 9th 07, 07:08 PM posted to rec.aviation.piloting
Grumman-581[_1_]
On Tue, 09 Jan 2007 13:17:32 +0000, in
28, Bob Moore wrote:
I think that you are going to have to work with TAS instead of GS, but
Figure 2.29 on page 179 of Aerodynamics for Naval Aviators has a graph
Yeah, to be perfectly accurate, I would need air speed and not ground
speed in addition to wind angle corrections, but I was curious if I could
get a good approximation of the bank angle from just what I'm getting from
the GPS without having to add a considerably costlier device like an
accelerometer / gyro with rs232 outputs... The Garmin 18 5Hz puck type GPS
goes for around $150... A bit more than the 1Hz units that are typical for
car navigation, but not entirely out of line for this project... The
accelerometer / gyro systems that I've seen so far with rs232 outputs go
for around $1K-$2K... I understand that there is some new work in
accelerometers for PC-based pointing devices that have brought the prices
down considerably compared to the previous devices like this:
http://www.watson-gyro.com/products/...A_80_spec.html
Old January 9th 07, 07:58 PM posted to rec.aviation.piloting
Grumman-581[_1_]
On Wed, 10 Jan 2007 00:03:22 +1100, in ,
v= velocity
PI =3.14159
for SI use v in m/s
g = 9.8 m/s^2
t in seconds
v in ft/sec
t in sec
Thanks Terry... Couple of questions though...
1. Is the resulting bank angle in radians?
2. Does the formula for the bank angle actually have "2*PI*v / g*t"
in it or was it supposed to be "2*PI*v / (g*t)"?
Old January 10th 07, 03:51 AM posted to rec.aviation.piloting
Grumman-581 wrote:
The accelerometer / gyro systems that I've seen so far with rs232
outputs go for around $1K-$2K...
You can get a 3-axis accelerometer with analog output for around $300.
I recently used one like this
http://www.xbow.com/Products/product...s.aspx?sid=185 for a project
in a ground vehicle. I used a three-axis one that takes power and gives
you three analog outputs X, Y, Z. The same company also sells an RS232
A/D board but IMHO it's a little spendy at $300. If USB is OK I know
you can get small USB DAQ boxes from several different vendors. I was
using an older National Instruments full length ISA card, but then again
it was OK for me to have an entire desktop PC case in the back seat of
the car.
None of this stuff is official aviation stuff (nice aluminum box, round
connectors, etc) but then again it doesn't have an official aviation
price tag either.
Standard disclaimers apply; I don't get money from any of the companies
mentioned.
Matt Roberds
Old January 10th 07, 08:31 AM posted to rec.aviation.piloting
d&tm
news
v= velocity
PI =3.14159
for SI use v in m/s
g = 9.8 m/s^2
t in seconds
v in ft/sec
t in sec
The bank angle is in what ever units you want. it is the angle expressed as
degrees or radians that gives a tangent of 2*PI*v /( g*t)
(sorry I should have put in the brackets)
check your equation with a standard rate 1 turn. At 100kts a rate 1 turn
will have t =120 seconds and give a bank angle of 15.4 degrees.
terry
Old January 10th 07, 09:54 AM posted to rec.aviation.piloting
Grumman-581[_1_]
On Wed, 10 Jan 2007 18:31:29 +1100, in ,
expressed as degrees or radians that gives a tangent of 2*PI*v /( g*t)
(sorry I should have put in the brackets) check your equation with a
standard rate 1 turn. At 100kts a rate 1 turn will have t =120 seconds
I tried it both ways today and pretty much figured that it needed the
parentheses around the "g*t"... The atan function was returning things in
radians, so that's what gave me the brain fart...
I'm getting approximately 15.175 degrees for a bank angle, but that's
probably because I'm using a more accurate measurement for pi and g... Not
that it is likely to really matter since when I graph it, putting it to
the nearest degree will probably be accurate enough... Haven't decided if
I want to redraw the gauge each time or have a set of predrawn images that
I shift around indexed by the bank angle...
Thanks for the help...
Mike Shelley
N581 -- AA5A -- AXH
Old January 10th 07, 02:05 PM posted to rec.aviation.piloting
d&tm
news
Its close but is it close enough at greater angles.? what are you using for
the conversion of speed.? I used g =9.8 Pi as 3.14159 and v = kts
*1852/3600 m/s
terry
Old January 10th 07, 09:14 PM posted to rec.aviation.piloting
Chris
"d&tm" wrote in message
news
v= velocity
PI =3.14159
for SI use v in m/s
g = 9.8 m/s^2
t in seconds
v in ft/sec
t in sec
as
terry
As an approximation
speed in metres/second is half speed in kts eg 100kts is about 50m/s
actually it is 52m/s.
UAV's and TFR's along the Mexico boarder John Doe Piloting 145 March 31st 06 07:58 PM
Air Force One Had to Intercept Some Inadvertent Flyers / How? Rick Umali Piloting 29 February 15th 06 05:40 AM
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 04:55 AM
Most reliable homebuilt helicopter? tom pettit Home Built 35 September 29th 05 03:24 PM
Mini-500 Accident Analysis Dennis Fetters Rotorcraft 16 September 3rd 05 12:35 PM
