Can Washout Cause Flutter??
Old January 16th 07, 04:48 AM posted to rec.aviation.homebuilt
DonMorrisey
Default Can Washout Cause Flutter??
A friend's homebuilt recently went down with an 8000 hour pilot at the
controls. No one was hurt and the plane was landed in a field. The
pilot reported hearing/feeling an extremely loud vibration from the
wing, he immediately killed power and landed. One of the wings was
visibly buckled. The airplane is all aluminum with a 36 ' wing span.
The NTSB showed up and after getting the plane to a hangar, the wing
was dismantled. The rear spar had failed and was twisted and buckled,
although the wing had held together. The NTSB guys said the very solid
structural design and construction of the wing was what saved the plane
from coming apart in the air, as well as the pilot's quick response.
The conclusion by the NTSB was aileron flutter, they found several
bolts in the aileron hinge bracket assemblies (which hold the aileron
to the rear spar) that were supposed to have been drilled 10 MM from
the top and bottom edge of the spar flange and these had been drilled
at 25 MM or so. That was it and they walked away. There was no
visible damage to the aileron, the aileron spar or the hinge bracket
assemblies. The pliot reported no vibration in the stick. My friend
is convinced it had something to do with the washout of the wing. The
wing is a NACA 4413 Airfoil, modified in that it has no undercamber on
the bottom, the bottom is flat. The washout, which is built into the
wing during construction, is a couple of degrees. The plane I am
building uses the same wing/washout. I have done research but can't
find anything specific linking washout to flutter.
Any thoughts on this??
Thanks. Don...
stall strips ??? Tri-Pacer Owning 6 December 8th 06 07:18 PM
Counterweighting to prevent flutter [email protected] Home Built 11 June 10th 05 04:51 AM
Stall strips vs. Washout [email protected] Home Built 27 February 27th 05 09:59 AM
Avoiding Vne K.P. Termaat Soaring 120 April 7th 04 08:56 PM
Tail flutter! I Can Computer Services Home Built 3 November 24th 03 01:56 AM
