WinPilot Design Center Access Problems?
Old January 20th 07, 01:35 PM posted to rec.aviation.soaring
Frank[_1_]
Default WinPilot Design Center Access Problems?
I recently purchased a WinPilot PRO license, and I have been attempting
to register/access the user support area called the Design Center, with
no success at all. I registered & got feedback from the site that an
activation code had been sent to my email address, but nothing
received. I have tried several times, with the same result.
Emails and phone calls to WinPilot and to CraggyAero have not resolved
the problem. Anyone else have this problem or know of a solution?
TIA,
Frank
Old January 20th 07, 03:12 PM posted to rec.aviation.soaring
Gary Emerson
TIA,
Frank
did you check your "junk mail"?
Old January 20th 07, 05:24 PM posted to rec.aviation.soaring
Tim Taylor
TIA,
Frank
Frank,
I tried the same about a month ago and got no response. I am not sure
the system works.
Tim
Old January 20th 07, 10:41 PM posted to rec.aviation.soaring
Frank[_1_]
Tim,
Thanks for the reply - do you know if there is any other official or
unofficial user support group for WinPilot? I have done a pretty
intensive evaluation of the product over the last month or so, and I'm
now trying to determine if the features/bugs I have probems with are
just me, or commonly encountered by others as well.
Richard at CraggyAero is a great resource and he is very knowledgeable,
but one person doesn't make a user community ;-)
Regards,
Frank
TIA,
Frank
Frank,
the system works.
Tim
Old January 21st 07, 03:52 PM posted to rec.aviation.soaring
Tuno
Frank,
I don't think the system you're referring to has been used the way it
was intended in years. Lack of participation I think. I recall trying
to use it in 2003 and giving up fairly quickly.
But I have been able to get all the support I need from direct e-mail
and from this forum.
-ted/2NO
Old January 21st 07, 06:27 PM posted to rec.aviation.soaring
Frank[_1_]
Ted,
Thanks for the information - I think you are correct that the "Design
Center" is moribund. Based on my experience so far, I could believe it
died not for lack of interested users, but due to lack of response from
Jerry ;-).
Frank
On Jan 21, 10:52 am, "Tuno" wrote:
Frank,
-ted/2NO
Old January 22nd 07, 06:34 PM posted to rec.aviation.soaring
Tim Taylor
Frank,
I have found that Jerry will usually respond within a few days to
specific questions. Richard is very good at working to help find
solutions. This group works well for general questions and I agree
that a place to post specific questions and suggestions would be nice.
Not sure if it is a big enough community to make a Yahoo group, but
Glider Forum would be a good place to start. I like the fact that it
has history that is easy to review.
I hope Jerry will add the ability to have multiple pages of
information. That would be the biggest improvement from my
perspective. If you have specific questions e-mail me directly and I
can try to help. The learning curve is a little steep, but once you get
used to it WinPilot is easy to use and configure.
Tim
Frank wrote:
Tim,
Regards,
Frank
CRS: V-22 Osprey Tilt-Rotor Aircraft Mike Rotorcraft 3 September 27th 06 04:44 PM
CRS: V-22 Osprey Tilt-Rotor Aircraft Mike Naval Aviation 0 October 14th 05 08:14 PM
Bush's Attempt to Usurp the Constitution WalterM140 Military Aviation 20 July 2nd 04 04:09 PM
Ice meteors, climate, sceptics Brian Sandle General Aviation 43 February 24th 04 12:27 AM
