Wing Tape - Does Thickness Affect Performance?
Old January 22nd 07, 11:13 PM posted to rec.aviation.soaring
ContestID67
Default Wing Tape - Does Thickness Affect Performance?
No, this is not SPAM as the subject line might lead one to believe.
I have seen lots of wing tape. Many of the advertisements are for very
thin and flexible tape which conforms to the curves of the wing.
However, the cost can be prohibitive, especially if you assemble often.
A friend of mine (very high time & competitive pilot) uses 3M
electrical tape. We got to talking about it and we agreed that this
high quality tape is very flexible, has good temperature properties and
not very expensive. Easy to find also.
The only issue then was the thickness. Wouldn't the edge of the think
tape affect performance? The friend pointed out (correctly) that the
tape runs perpenticular to the span of the wing and thus the tape's
edge is parallel to the air flow. Thus no performance issues.
Any thoughts? What about with bug whippers?
Enjoy, John
PS There is one issue with 1/2" wide electrical tape - whether it is
wide enough to bridge the gap. It all depends, I suppose, on the fit
and finish of your glider.
Old January 22nd 07, 11:27 PM posted to rec.aviation.soaring
JS
I / we own toys that cost a hell of a lot of money, mine more than the
purchase price of my house.
The idea of a bit of tape being expensive boggles the mind.
Buy six rolls from Mike Bowlus. It's great stuff. His hats are great
too.
Legal disclaimer, I don't work for Mike.
Make sure all your overlaps don't give you an additional tape leading
edge, ie: on AS-W27 or similar, start at the trailing edge and overlap
the three pieces on each side.
Old January 23rd 07, 01:37 AM posted to rec.aviation.soaring
Speak for yourself, some of us are in this sport because its cheap fun.
I only taped the Cherokee a few times this year. my longest flights
came without tape.
Old January 22nd 07, 11:41 PM posted to rec.aviation.soaring
01-- Zero One
"ContestID67" wrote in message
ups.com:
Actually, I believe that not all the airflow is parallel to the
streamline. For instance, on the top aft half of the wing or so there
is a low pressure area and I think that pulls air from the fuselage area
somewhat laterally out onto the wing.
Nope, I think you need to try alt.sex.insects.bondage group for that.
Larry
01 "zero one"
LS-3a USA
Old January 23rd 07, 04:32 AM posted to rec.aviation.soaring
Tape drag not a huge effect, but can add up to 10 or 15 points over the
course of a contest. That's why many top Euopean contest pilots use a
special putty compound to smooth over the tape edges. It's a bit
tedious for a single day's flying, but if you're going to stay
assembled for a week it's not so bad.
Enjoy, John
Old January 23rd 07, 08:57 AM posted to rec.aviation.soaring
Bert Willing
What a nonsense...
Old January 23rd 07, 09:54 AM posted to rec.aviation.soaring
Dan G
Got any evidence for that?
Dan
Old January 24th 07, 11:09 PM posted to rec.aviation.soaring
Udo
course of a contest.How many days would that be? Can you also tell me how many points it
costs for the drag of an open airvent and an extended pee tube?
Andy
I am do not know about the tape, but a 6"-7" pee tube could generate
about .2 lb of drag at 85 kt, hence a one day contest base on a 1000
points, all else being equal, could reduce the points count by 12-15
points.
Udo
Canard planes swept wing outer VG's? Paul Lee Home Built 8 January 4th 04 08:10 PM
Props and Wing Warping... was soaring vs. flaping Wright1902Glider Home Built 0 September 29th 03 03:40 PM
More long-range Spitfires and daylight Bomber Command raids, with added nationalistic abuse (was: #1 Jet of World War II) The Revolution Will Not Be Televised Military Aviation 161 September 25th 03 07:35 AM
Can someone explain wing loading? Frederick Wilson Home Built 4 September 10th 03 02:33 AM
